Question about Kenmore Dryers
I have had a Kenmore, model # 110.64962300 for a few years. Was running fine until last night it just stoped mid cycle. Then, no power from start button. I have no electrical or wiring diagram to go by. Not a household breaker/fuse problem. Any fuses in the unit that may have blown?
  • 10,865 Answers
Go to the site Sears Parts Direct. Enter your model number and you will see a complete set of diagrams for your model. Chances are a fuse did blow.
You will see that in the diagram and you can order one there on line if u choose to. J.
Posted on Sep 11, 2010
Washer stops mid cycle
ur drain is stoped up. the drain emptys into the sink plumbing...
Oct 17, 2013 | Admiral Washing Machines
Kenmore Dryer
What is the model number of your unit?
Nov 26, 2012 | Kenmore Dryers
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Microwave -SE- code
I have the same problem with my microwave and i cant fix it help?
May 10, 2010 | Kenmore Microwave Ovens
Dryer stops mid cycle-restarts when cooled down--is it some sensor?
Good day,
Yes it's a sensor, but if you have to restart it manually after the cool down period, it is the sensor built into the motor.
That sensor measures motor temperature and current draw. It locks out the motor until it reaches normal temperature.
If it restarts on it's own, then post back with the complete model number. It would be a different problem.
Mar 09, 2010 | Kenmore Dryers
Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Oct 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Kenmore side by side fridge not freezing after pwr went out for few hours
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Hotpoint HSS25GFP Side by Side...
Dryers Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
