Check the fuse behind the stereo and in your fuse box first off and make sure the power wire/ignition wires are on the correct pin. do this with a test light for verification. also check the ground wire. after you test and connect these 3 wires, the stereo should turn on. Your wiring harness may not be done correctly so visual verification with a test light would be the best thing before starting a car install. If this still does not work and the stereo you took out did, it is a malfunctioning unit.
Update to my last post. Newer cars also have to have the buttons on the dash reconnected prior to testing the unit or else the check engine light will come on. (new) good rule of thumb is to connect everything and reinstall the dash prior to testing the unit. After initial testing, you can go back and troubleshoot. Other option is to keep obdii tester on hand to reset the check engine light.
