Question about Maytag MDE9700AYM Electric Dryer
The drum of the dryer is rubbing on the on the back when it turns.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Have a 2780 dryer stackable that is leaving grease/burn streaks on my clothes. it seems that lower front of drum is not sitting flush. there is a gap against the wall where clothes or dryer sheets get...
you need replace drum support roller,an check to make sure drum hadnt cut into back are the front of dryer the felt that drum roll around on may allso need be replace.some ge dryer have single bear it roll around on it attack to back of the dryer drum
Feb 28, 2018 | GE WSM2780DWW Unitized Spacemaker Washer...
Maytag dryer model MDET236AYW drum rubs against blower = loud squealing. drum slides forward and back about 1/4 to 1/2 inch. when slid back, it rubs against blower. when slid forward, does not rub. how can...
heatman101
Feb 21, 2011 | Maytag Dryers
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Jul 10, 2010 | Crosley CDE6000 Electric Dryer
The dryer was squeaking when it was on but know it
possible worn bearing.the more wear on the bearing the lower the drum will be.the drum sounds like its rubbing the bottom of the dryer.check for black dust behind the dryer
Feb 20, 2010 | Amana Dryers
Drum seems to be rubbing and making noise when turning
the drum does rub ... generally, there is no front or back to a drum. It rides on the rim on the back and on a smaller rim on the door. I normally find a felt "bearing" at these locations. and sometimes, there are wheels at the back on the bottom. Gravity and the drive belt make it work.
I hope this helps you
a
Sep 23, 2009 | GE DBSR453EBWW Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer squeaks while drying sounds like drum rubbing on something
A squeak can also be a slipping belt or something caught between the drum bearings usually the front but could be the back one.
Jun 14, 2009 | Dryers
Kenmore dryer front of drum rubs
Check your plastic drum slides. I get em(2) out of the drum and reverse them and that sometimes stops it.
Feb 14, 2009 | Kenmore 62602 Electric Dryer
Drum rubbing on inside walls
Go into the back of the dryer. Remove access to back and you will see the drum. Chances are your motor that turns the drum is loose or the shaft or spindle that the dryer spins on is loose from its bracket. Tighten all that up and it should be fine.
Jan 30, 2009 | Dryers
Miele T 1515 electric dryer
Blower fan has fluff on stuck to it. It may even be disstorted. If you are really unlucky then it's done the blower fan motor bearings as well.
Dec 03, 2007 | Miele Novotronic T220 Electric Dryer
Maytag MDE9700AYM Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
