Question about Thermador C302U Electric Double Oven
We have a Thermador C302UB Double Oven. We cannot select the Lower Oven. Normally when pressing any button on the control panel there is a "beep" to acknowledge that a button was pressed. There is no "beep" when you press the Upper/Lower control panel button and the upper oven stays selected. It appears that the Upper/Lower control panel button is not working. All of the other control panel functions seem to be working we just can't select the lower oven.
  • 1 more comment
  • robertsta345 Sep 12, 2010
    I removed the front control panel and disconnected all of the connectors. I did not see any obvious solder problems or an easy way to check for conductivity with a meter. I'm assuming that the problem is probably with the TouchScreen Technologies board P/N 16-10-089-02. This is the board that has the touch button that selects between the upper and lower ovens. I was very careful when I disconnected the cable assemblies and the connectors are all polarized so you cannot mix up the connectors. Anyway, after I reassembled the control panel and I turn back on the circuit breaker the clock appears and then I get an error code F:11 followed by 3 beeps. It then switches back to the clock display and then back to the F:11 display followed by the 3 beeps. It continues to cycle between the clock display and the F:11 display. Interestingly, the function key that selects between the two ovens does appear to at least be recognized now. I disassembled it again to see if there was any obvious connection problems but everything looks fine and with the polarized connectors it's pretty much impossible to mess things up. Do you know what error code F:11 means and/or have any idea to what I might have messed up? Before I removed the panel we at least had the use of the upper oven. Now we don't have either. Thanks.
  • robertsta345 Sep 14, 2010
    Okay, After I got the F:11 Error Code I re-removed the control panel. There was nothing obvious (Even though I was very careful I thought that maybe a pin on one of the connectors got bent) so I reinstalled it. The connectors are all polarized so it's impossible to get them mixed up. After I reinstalled it I was back to square 1 but at least I no longer had the F:11 Error Code and the top oven could be used. The wife was really upset when we went from one oven to zero.
    I did visually inspect all of the solder connections with a magnifying lens and they appear to be fine. It's very difficult to actually get a meter on them since the PCB has a coating on it. Is it possible that the cable that goes from the Left Touch Control Panel P1 connector to the Display Head P1 connector has a loose wire. The connector uses insulation displacement to make the connections.
    I didn't notice any signs of water in the control panel. I'm pretty sure that the problem is either in the Left Touch Control Board or the connection between it and the display head. The new control panel assembly is about $300.
    http://www.repairclinic.com/SSPartDetail...
  • 944 Answers
The problem lies in the control and harness assembly. Bad solder on the control pin connector will cause this type of issue. you will need to solder the pin in the control panel.Some times short circuit in wire might cause this issue.So see for any damage in the wire and loose connections in the door.This is 100% soldering problem.Use multi-meter to check you are getting proper readings.Check for water marks on the control board.Some times water on the circuit board will cause short circuit and may also cause this issue.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 11, 2010
  • 2 more comments
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 12, 2010
    F11:Serial communication error:
    Communication between the Central Control Unit (CCU) and the Motor
    Control
    Unit (MCU) cannot be sent correctly.
    Please check the connections correctly.Since there some loose contact in the wire this problem is coming.F11 error code.Just use the multimeter to check the connections.See the change in reading using it.Do continue testing so that you can easily find out the exact reason.
    Control
    Check Wire Harness connections to the MCU, the motor, and
    Central
    Control Unit (CCU)
    Check the Drive system for any worn or failed components
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    Replace failed component.
    If you don't have hands on please don't mess up.Thank you.
    TouchScreen Technologies board:See the copper lining on the board to have any water type of rust marks.If so it needs to be replaced.
    Natarajan Ramasamy Sep 14, 2010
    I have a doubt on the connection between it and the display head.How much year old is your Oven.After 3-5 years only we usually get the control board problems that will be fully defective.
    The oven is almost 8 years old.
Oven won't start
Try pushing the "convection oven" or "bake" button first, then enter the temperature you want. Then "Start".
Sep 24, 2012 | Thermador SC272T Electric Double Oven
Thermador oven sc272t f-c code I have a F-C code on the oven and it beeps continunually. Do I need to call a repairman?
Hello, welcome to FixYa.
Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display.
Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately).
In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units.
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 23, 2011 | Thermador SC272T Electric Double Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Oven displays Off with every button you push
touch panel has failed . may need replacement . . this unit may require a update kit .. ( new p c control and panel .. ) very costly. mm
Jul 13, 2010 | Thermador SMW272 Electric Double Oven
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Nov 27, 2009 | Thermador SC302T Electric Double Oven
Thermador oven timer doesn't repeatedly chime for 5 minutes anymo
I just fixed my timer! Press and hold the OFF button for 10 seconds (until you hear 1 chime). Thanks to David at Bosch/Thermador!
Nov 17, 2008 | Thermador SC302T Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Thermador C302U Electric Double Oven Logo
141 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
