Question about Dishwashers
Manual for diplomat adp8224 dishwasher - Dishwashers
My diplomat ADP8352 started the cycl then stopped and was continually beeping. the three lights at the left hand side flashing. help???
Check the manual and see if it can diagnose the problem. Or you may need to have it checked. http://www.manualslib.com/manual/277803/Diplomat-Adp8352.html
Oct 26, 2014 | Dishwashers
Diplomat ADP8342 won't fill with water
Assuming the water tap is open and the water pressure is correct, it is likely the inlet water valve in the dishwasher is faulty. If you hear a click at the time the cycle starts but still there is no water then the inlet valve needs to be replaced. Also check the inlet hose for any kinks or blockage of the filter attached to the tap inlet.
The inlet valve looks like this item
Diplomat ADP8342 Solenoid Valve
Aug 05, 2014 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Mar 09, 2008 | Dishwashers
Dishwashers Logo
298 people viewed this question
Top Dishwashers Experts
Owen Barnes
