Go to Menu->Setup->Phone->Display. Or something on those lines in Motorola. You will get the chance to set the intensity and duration of the back light.
The display and backlight are the biggest users of power for any computing device. You can lower the display brightness and on some even lower the backlight intensity to conserve power, but this will have an impact on your viewability.
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
You are right ,the problem is in the backlight. There's a loose connection in the connector of the backlight to inverter or driver.The backlight have high voltage supply,so if the coonector is mildly loosen,it may cause of voltage drop produce and spark and over heat the connector,and totally result of loose connection.So the things you can do to fix the problem ischeck the connection of the backlight.Open the back cover and look the board,located at the center part.It has a metal cover in the board,remove the cover and check the connector of the backlight,Resolder and tightly press the connector to the inverter or driver.It is usually happen to the backlight of the LCD TV.Just fix the connection of the backlight.Try my suggestion and procedure,.Hope it will help you..Thanks..
Usually in that case the problem is the backlight.There is no supply in the backlights cause of loose connection because the backlight have high voltage.The connector of the backlights at the board or driver supply is loosen.So its better to check the connection and resolder or fix the connection.Thanks..
easy fix my friend its temporary firmware problem . ok now to fix it
plug the sansa in your pc ,just doing so can fix the problem if not
,unplug it from the pc the unit should have stayed on (the blue LED's of
the wheel r on but no screen backlight) push the ON button on the side
and hold it push for a good 20 secon then releass it that will make the
unit do a soft reset and then turn it back on again it may chow the low
bat simbol just plug it back in your pc the screen will show the
turning arrow the backlight of the screen will work, let it recharge
and there you go fix.
Sounds like the flex cable has failed. I have the N1 and when the flex cable snapped, the screen still worked, but the backlight is off. Pioneer issued a recall of the flex for N1 and N2's. They will fix it for free.
