Question about Fisher and Paykel (IWL12)
Display says power cut and all lights flash and powers back on but it happens every minute or so.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue seems to be with the control board going bad and should be replaced however, before replacing the control you can take it apart and try to blow some air with the help of hair dryer, if still its not resolved then you’ll have to replace the control. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 11, 2010
KDF-60XS955 Powers off and on every minute
The lamp light will not come on especially if it lights up during bootup from a cold start. The lamp only lights up on Sony when the lamp shatters in its housing and the system can't ignite the lamp from a cold startup, Sometimes it does'nt light up then. So if it lights when u first cut it on the sysem thinks its ok... But lets verify if the lamp is the problem.
With the tv off using your original remote, Press Display button-----channel 5 button----and Volume up button then Power button within 5 secs of pushing the first button, Screen should come on with a diagnostic screen, Look at the lamp driver option and see if its recorded any numbers to the right of it, if so then this is telling you that the lamp has stopped or tried to ignite that number of times..
Push the number 8 key then enter to reset the numbers back to zero.Turn off power now turn on the television and wait until it happens again, at this point go back to diagnostic as explained eariler and see what it has recorded. If it has recorded a 1 on the lamp driver then replace your lamp. Reminder: Once you have replaced the lamp go to diagnostic screen again and reset the numbers back to zero.
Hope this helps...Thank you
Delhielectronics@live.com
Sep 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
E1 Flashing on display, air cut off
There are steps listed in the user manual which can be downloaded from:
http://www.sharpusa.com/...
/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf
You also need to hold the power button when plugged back in. If that doesn't work, there is another step as well.
Aug 23, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
Power cuts out on PT-53WX42
unplug tv check the fuse and the rating on it,.see if filament inside is burnt
Oct 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Washing Machines Logo
26 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
