Question about True TD-95-38-LT Beverage Cooler
Yes I have a True 95 38 Beverage cooler and I bought it new 4 years ago , I have used it for 3 and 1 year it just sat not running , well I plugged it in the other day and it is only blowing warm inside and not getting cold , but the air is blowing out of the vents in the back and sides what could be causing it not to cool down and get cold inside ? I have checked the coils and they seem to be pretty much clean .
    Novelist:
  • 112 Answers
Could be many things... A bad thermostat, bad compressor, bad compressor start relay, refrigerant leak, moisture in the system, or even a blocked capillary tube. You would need a lot more information... mostly only the kind a technician can get by getting his hands on it. Sorry.
Posted on Jan 19, 2011
How do you remove the evaporator cover on a Tbb-2 cooler?
PDF]True Manufacturing Company, Inc. - Fixitshop.com
https://fixitshop.com/manuals/TECHNI~1.PDF
Top Removal for TBB and TDD ... Top Removal for Various Coolers - TSSU, TWT, TUC ... End Cap Replacement-T-Series Swing Door ... GDM 2 Door Cooler IDL Light Diagnosis ... If you keep the Condenser clean you will minimize service ...
[PDF]installation - True Manufacturing
https://www.truemfg.com/assets/...Website/TDB_TBB.../tbb_english.pdf
Your TRUE cooler when properly maintained will give you many years of trouble-free service. TO LOCATE REFRIGERANT ..... Removing bracket from skid. Removingbracket from cabinet. 1. 2 .... tab holding the door cord slides out the back. ... The switch is located on the front of the evaporator housing toward the front of .
Nov 08, 2015 | True TBB-2G-S Stainless Steel Beverage...
I have a beverage air MM14GE cooler that hasnt been on for over a year when i plug it in it turns on but doesnt cool, what can be the problem?
Verify that the compressor is actually running. You should feel it vibrating. If the compressor runs with no cooling most likely the refrigerant level is low.
Oct 12, 2013 | Beverage-Air Refrigerators
Have an 86 marquis 5.0L that keeps over heating, I've replaced the water pump 4 or 5 months ago and it's now doing the same thing again. Sometimes I can make it 3 or 4 miles and sometimes 20...
If the radiator is quite old check the condition of the fins on the cores as they are probably flaking off and not transferring the heat. IF you find that the radiator is blocked I would suggest a good block flush out before you fit new radiator or it will block up from the gunk in the block. Replace the viscous fan hub as this is a prime source of overheating especially at idle. Check the timing and distributor operation. Check all rubber hoses for cracks and vacuum leaks as a lean running motor will overheat. have a pressure test done on the transmission as a gearbox that has sat for so long will have gum deposits inhibiting correct operation of the gear box and this will cause box oil getting hotter than normal which is transferred to the cooler in the radiator tank. Ford radiators are barely good enough at the best of times so an external cooler for the transmission is a very good idea for both the engine and the box oils.
Aug 17, 2013 | 1996 Mercury Grand Marquis
True TD-95-38-LT Beverage Cooler wont drain , cannot locate drain plug
Usually inside the compressor compartment, below that is the collection pan, blow it out with compressed air
Feb 01, 2013 | True TD-95-38-LT Beverage Cooler
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
True cooler td 65 24. what is holding the sled in place
I think you are referring to the condensing unit that the compressor sits on. Look on the rite side of the unit near the bottom. There you should find 1 3/8" screw that runs through the side of the unit into the "sled" thus holding it in place.
May 03, 2009 | True TD-65-24 Commercial Refrigerator
Problem with a True TD-50-18
That is the drain which may be clogged. Look for hose in pan by compressor and use one of those cans of air to blow out computer keyboards.
Apr 26, 2009 | True TD-50-18 Beverage Cooler
HABCO ESM12 blowing warm air
first see if compressor is running at all if is not it might just be a realy or overload
Oct 31, 2008 | Danby DKC645BLS Compact Beverage Cooler
I can't get the fluorescent tube to light up when the doors open.
Most fluorescent lighting have ballast in them it more then likely just needs replaced. I have included a how it works link for you HERE
I hope this helps you fix your beverage cooler.
Aug 14, 2008 | True TBB-2 Beverage Cooler
True TD-95-38-LT Beverage Cooler Logo
361 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
