Question about Samsung SpinPoint T HD501LJ 500 GB SATA Hard Drive
Computer won't boot up and says nothing is installed in SATA 0 but it is there. What can I do to fix it?
  • Samsung Master
  • 27,725 Answers
Replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 11, 2010
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
Dell inspiron 531 wont boot saying SATA 0 installed SATA 1 installed SATA 2 none SATA 3 none
Johnathan,have you changed anything in BIOS.set optimal defaults ?
if BIOS can change BOOTDRIVE.windows are in one of the drives.
Aug 18, 2013 | Dell Inspiron 531s Desktop Computer
I get a disk read erroroccurred after I have installed a new hard disk. How can I get my computer going again?
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 15, 2012 | HP Compaq nx6325 Notebook
I am trying to format my hard drive on my stalite l305=s5875. i shows the hard drive in bios but when the windows disk looks for it theres nothing there. no hard drive appeares
If your laptop has a SATA hard drive then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | Toshiba Satellite L305-S5875 Notebook
WINDOWS 7 WON'T RELOAD
Before reloading Use a system utility tool like Reginout for an instant fix.
Apr 13, 2012 | Apevia Computers & Internet
My inspiron 531 says no boot device available
Computer is not configured to boot from your hard disk drive (SATA 0),
you need to go into the BIOS (set-up) menu and make that drive the fisrt boot device.
Feb 15, 2012 | Dell Inspiron 531s Desktop Computer
Inspiron 531 wont boot up. just get dell screen then says Sata 0 Sata 1 Tsst corp DVD sata 2 None sata 3 None
If yo are sure that you have a working operating system on your hard disk , and this error started after you (probably) defaulted the Bios settings or something else did ....Than I think the lack of sata raid driver makes the reading of your hard disk impossible ..To fix this ..either try to reinstall the operation system and during it ..choose to add a 3rd party driver (look for raid driver on your motherboard cd ..or on the manufacturer's support site ) ..or ..just get into Bios again ..look for the HDD in the advanced options ..and select the hdd 0 ..and eliminate the achi feature ..and replace it with sata as ide ..or compatible ..and save settings with F10 and restart ..It will make the hdd visible ..and support installation if it has non ...or just boot up ..but will work as IDE and not raid ..
Aug 23, 2011 | Dell Inspiron 531s Desktop Computer
I have a Compaq Presario Desktop Computer SR1150NX. I've added a new WD SATA 1 Terabite HD. but the system does not recognize it. I updated the Bio's but see no way to activate the SATA ports. The...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Computers & Internet
Stop;0*000000*7b(0*f896863c,0*0000034,0*00000000,0*00000000)my computer shows a stop error screen every time windows opens
INACCESSABLE_BOOT_DEVICE = there's something wrong with your hard disk - either its driver is missing or it's the wrong one or the MBR was corrupted.
Start by fixing the MBR by booting into the Windows XP recovery console and run the command “  fixboot ” followed by “ fixmbr ”.
After that boot in Safe Mode and install the latest driver for the chipset and SATA/RAID.
May 26, 2010 | ASUS P4S800D-X Motherboard
Samsung SpinPoint T HD501LJ 500 GB SATA Hard Drive Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
