My Drive C was deactivated how do I activate it
  • 4,924 Answers
If your computer is starting this means that your drive C is not deactivated cause that is the drive with the windows in it ...Maybe you reinstalled the computer and not knowing exactly what you are doing you installed the windows in the drive D and during the installing you formatted and left the drive C like un-partitioned space ..Even in this case the drive that is showing should have 2 letters C in the secondary ..
or you just formatted it all and made a single partition instead ..cause there is no way to disable the drive C not even to hide it like a folder in fact you can not hide a partition ..so ..either you installed dual boot and you booted from the D partition ..and the C is not showing on the right letter (they change the letters when you boot from one or the others ..
My advice ..if you found your files that you want to save ..put them on a memory stick and store temporary n another computer ..and after that ..boot from CD to install windows..re build all partition s..install windows correctly and will be a solved problem ..
at least when you boot until the partitions you will see if they are present or not cause in there will be no way to hide them ..
There is the possibility that you have 2 HDD on computer and you installed in another and the one that originally had the operation system is not see cause it is either disabled or the raid driver is missing ..but you have 2 windows on it anyway in this case cause it will not start up (boot) without a viable windows..
in all case you can also try to go to bios by pressing del on start ..(f10 if it is an HP) and in there look for something called factory optimal defaults and enable it ..confirm with enter ...than save with F10 and enter ..after that if you have 2 Hdd 'es and 2 windows installed you have a chance that will show up..
Also try to install the Raid driver from the motherboard drivers disk ..if they are on Sata (at least the one in case ) will show up after reboot..
anyway you messed it up and I suggest to ask for someone that knows hes way better to fix it up..cause even if you boot from the original C drive you will have a hard time get rid of the windows in the other partition ..so ..just reinstall it clean ...format all partitions ..and pay attention where you install the windows..(use a diskette with the Raid driver if the C is not seen on installation ) and insert it when it says to press F 6 for 3rd party ..
Posted on Sep 29, 2010
  • 6,487 Answers
Can you please explain your problem further, Do you mean that you cannot boot your computer since Drive C is already deactivated? But if that will be the case and your hard drive is not detected anymore by your computer you may need to unplug and replug it to your computer and restart the computer after doing that.
Posted on Sep 11, 2010
How to desactivate only the hourly chimes alarm, in my taksun ts 613A
ask them. the manual doesn't appear to be available online.
Address :
Unit 9, 32/F., Cable TV Tower, No.9 Hoi Shing Rd., Tsuen Wan, N.T., Hong Kong
Tel :
852-2419 8831
Fax :
852-2408 1575 / 2409 0136
Contact Person :
Ms. JoJo Yeung
Email :
info@takshun.com.hk
URL :
http://www.takshun.com.hk
Oct 27, 2015 | Watches
Deactivate the hourly chimes in my TAKSUN TS-613A clock?
I am happy to tell you that THERE IS ANSWER:
In normal time mode press S, hold it, then then press D to activate (or press D again to deactivate) the alarm. You will see the symbol of Bell (above the seconds) appear (when alarm is activated) and the bell symbol will disappear (when the alarm is deactivated). Now if you FIRST press and hold D and then press S it will do the same thing (activate or deactivate the alarm). So D then S, or S then D will do the same thing for activation or deactivation of the alarm. BUT, IF YOU HEAR A BEEP (chime) SOUND when you activate or deactivate the alarm, then you actually ALSO ACTIVATED THE HOURLY CHIME!
BUT if you DO NOT HEAR THE BEEP (chime) when you activate or deactivate the alarm, then the Hourly Chime is OFF!
So (in normal time mode) try it both ways: first holding D and then pressing S, or first holding S and then pressing D (one of these will activate or deactivate the alarm WITHOUT MAKING A BEEP (chime) sound - USE THAT SEQUENCE TO DEACTIVATE THE HOURLY CHIME.
I hope this is helpful!
Mar 18, 2014 | Health & Beauty
How to deactivate numeric keypad and how to activate touchpad
to activate/deactivate numlock press F11 to activate/deactivate touchpad press F10
Jul 02, 2011 | Samsung N150 (36725723009) Netbook
My numeric keypad is activated how to deactivate it and how to activate the touchpad
to deactivate/activate the numeric keypad just press the F11 and to activate/deactivate the touchpad just press F10..Hope it will help you
Keypad on garage door will only close if i punch in my code it won't close by hitting the enter button the temp here is minus 40 does that effect the keypad chamberlain 3/4 belt drive
Try this procedure to reactivate this feature.
Opener can be closed by pressing only the ENTER button if the One Button Close feature has been activated. This feature has been activated at the factory. To activate or deactivate this feature press and hold buttons 1 and 9 for 10 seconds. The keypad will blink twice when the One Button Close is activated. The keypad will blink 4 times when One Button Close is deactivated.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
System is activated on five ps3's already...
Hi I had this issue what you need to do is log into your sony account and deactivate the old ps3 accounts from your ps3 username. https://www.playstation.com/en-au/get-help/help-library/my-account/device-activation-deactivation/remote-deactivation
Oct 31, 2017 | Sony Playstation 3 (PS3) Console
HOW TO DEACTIVATE IP DIALING IN CHINESE ALFATEL H1 ?IP DIALING IS ACTIVATED IN MY PHONE IN SIM1 AD 2?.HOW CAN I DEACTIVATE IT?I DONT WANT THIS.
Jun 26, 2009 | Handmark Software MobileLists (950142) for...
SIM LOCK
hi i locked my sim card, i went onto 02 website and went onto PUK code. it asks you to put your phone number in then comes up with the code. i put the code in and it it worked
Jun 26, 2009 | Samsung SGH-D600 Cellular Phone
Deactivate the touch pad
Try holding down FN key and F( key. This activated and de-activates the touch pad
Apr 25, 2009 | Toshiba Satellite A20 Satellite A25 Series...
SECRET CODES
SAMSUNG UNLOCK CODE....
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}][/b]
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class 1 GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
Mar 16, 2009 | Cell Phones
Computers & Internet Logo
David Payne
David Payne
