Question about Kenmore 42822 Front Load Washer
My machine will start the wash cycle, then when it's full of water, start beeping and flashing an error, FH. We replaces the pressure switch hose because it had a hole in it. It worked for 2 loads and started doing the same thing again. We checked the continuity of the pressure switch and it seemed ok but we are not sure. Any help you can offer would be appreciated.
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
Maytag Epic FH Error
follow this steps .God bless you
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
Jul 22, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whin washing 30 min left and it stops and flashes FH
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Mar 12, 2013 | Washing Machines
It has stopped washing and is flashing FH what is the problem and what should I do ??????
First try turning off the machine for 30 minutes. Still FH? Next check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Mar 06, 2013 | Kenmore Washing Machines
Hi Expert, I have the 9200 Whilpool Duet washer that is now stuck in the rinse cycle and is 1/2 full of water. I tried to drain it by lowering the hose into a pail but no luck. I get the FH code. I have...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
Every time i turned on washer after 2mins into wash it will start to beep and the letter F will start to flash immediately the letter H will flash as well. It does not matter at what level or load I...
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Jul 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When washer starts to wash it beeps and flashes the letters FH.
Hi
Error FH means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
Jan 17, 2011 | Maytag EPIC MFW9700S Front Load Washer
Error code fh the and the machine would not drain
I know you said you had done all this, bhut these are the commentsstraight from CD manual.
Kenmore Elite 2 front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation. You can read about the water valves used on appliances at the following link:
LINK > http://www.appliance411.com/links/jump.cgi?ID=801
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose (see the following link).
LINK > http://www.appliance411.com/links/jump.cgi?ID=534
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents.
please rate this help to keep the service online
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops about half way thru cycle anf error code HF appears
Or
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite
hi,
Or
hope this helps.....
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 42822 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
