Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Refrigerator is freezing everything,settings have been the same for 2 years.
  • 2,382 Answers
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try:
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
But it is mostly a thermostat problem.
Posted on Sep 11, 2010
I have the Magic chef 18EYW-2 1.7 refrigerator and everything is being froze when set on 1. I have even tried setting on the preferred setting. Everything is still frozen. HELP! Thanks.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 05, 2011 | Refrigerators
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Frdge freezing everything
Check to make sure the thermistor is attached to the fins on the inside of the fridge. Otherwise you may have a bad control cable assy.
Jan 12, 2009 | Dometic NDR 1062 Refrigerator
Refrigerator freezes everything-on 3rd service call now
If you have had 4 problems in a year where Sears had to replace something, you are entitled to a new refrigerator according to the lemon law. Call the 800 number and they can review your service calls. We have had several problems with our refrigerator as well. (Ice maker, lightbulb burning the plastic cover, motherboard needed replaced and the strip that holds the two doors together fell off) Today the service man was there for the 4th time to replace the door strip. I called the number and they are processing the paperwork for a new refrigerator.
Dec 30, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
43 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
