Question about Ortho Dial N Spray Hose End Sprayer
The contents in the bottle doesn't come out - Ortho Dial N Spray Hose End Sprayer
    Problem Solver:
  • 14 Answers
Open the continer is there a small piece of hose connected to the lid if not connect it. the water creates a suction through the hose when it passes over the hole inside the continer to spray the contents of the bottle.
Posted on Sep 11, 2010
  • aljosada Jul 23, 2011
    the liquid in the bottle will not draw up the tube. have dissembled and reassembled and holes are not clogged.
    any idea why the solution will not draw up the tube? used to work perfectly.
Can you take bottles of alcohol in your carry on luggage or checked luggage
Carry on is OK, but must meet the TSA standards, same as all other carry on liquids. 3 ounces or less.
Checked is also OK, no limits, but pack securely to avoid breakage and pilfering by baggage handlers.
Mar 15, 2015 | Luggage & Travel
Fix an error message on the Ricoh Aficio 1224c that says 'used toner bottle full'? We have emptied the used toner bottle but the error message persists. What is the best way to fix this?
Check the waste bottle to see if there is a chip mounted on it somewhere. If not see if there is an optical sensor or clear window. If there is a chip it will need to be replaced or a new unit used. If there is a window or optical sensor you should be able to remove it, clean it out, and replace it. These are often the last part to fill with toner and create a light path block.
Feb 06, 2015 | Ricoh Office Equipment & Supplies
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
What does a simple rain guage consist of?
There are a variety of commercial rain gauges available on the market, however making a simple rain gauge is quick, easy and only costs as much as a plastic bottle. Chances are you already have everything you need to make this simple rain gauge, which is fun to construct, and interesting to use. Read on to learn how to make a simple rain gauge.
  1. Cut the top off of your plastic bottle. Cut about a quarter of the way down, to where the bottle begins to have a consistent diameter. Be careful to cut the edge as smoothly as possible, salvaging both pieces of the bottle.
  2. 2
    Remove the bottle cap and turn the top part of the bottle upside down, placing it into the bottom part. Connect the two halves with paper clips.
  3. 3
    Place the plastic bottle rain gauge in a location where it will easily collect rain without impediment from surrounding trees, plants or buildings.
  4. 4
    Help your rain gauge stand upright by placing it in a sand or gravel filled bucket. Simply make a hole in the sand or gravel large enough that half the bottle gauge sits into the pit. Use the gravel or sand to support the edges of the bottle gauge.
  5. 5
    Measure the amount of rain caught by your gauge by emptying the contents of the bottle rain gauge into a measuring cylinder.
Feb 07, 2011 | Home
Water comes out of the over flow bottle when its hot.
IS THE RADIATOR COVER SUPPOSED TO BE PRESSURIZED???
IF SO THEN YOU DON'T HAVE THE RIGHT TYPE, TRY THAT FIRST
IF IT IS SUPPOSED TO HAVE PRESSURE THEN YOU NEED TO LEAVE SOME BREATHING AIR IN THE OVER FLOW BOTTLE, REMEMBER TO NEVER FILL TO THE TOP.
Jun 22, 2010 | 1992 Toyota Celica
I need to empty the toner bottle but don't know how...images would help
I don't have images because emptying the waste toner bottle is a service tech function and is not covered in the user reference guides. However, it is not that difficult to accomplish. Facing the left side of machine, halfway down and at the rear is a panel attatched by a single screw ( panel is approximately 4" wide x 6 to 8" tall ). Remove this panel. Inside you will see a plastic bottle with waste toner in it. Remove bottle and 'carefully' pour contents into a lined trash can or plastic bag. Once emptied, wipe the opening of bottle (inside and out) especially where the round "sensor" windows are located. Now, reinstall bottle in machine and replace the exterior panel. Turn copier off at main power switch on the lower right side towards rear. Wait 5 seconds, power on copier....that's it.
Nov 03, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Sep 09, 2008 | Canon imageRUNNER C3200 Copier
Thermos bottle leaks
I didn't have a tv problem I bought a new Stanley Thermos bottle but it leaks out of the top. The stopper doesn' t keep it from leaking.
Jul 03, 2008 | Televison & Video
Ortho Dial N Spray Hose End Sprayer Logo
564 people viewed this question
Top Ortho Garden Experts
raysaw
Nick Olsen
Are you an Ortho Garden Expert? Answer questions, earn points and help others
