Question about Stanley Bostitch MIIIFN Flooring Nailers
Just had gun rebuild by bostich my m111fs flooring gun drives the staple to far into flooring and the piston sticks in wood as well. nate
    Sergeant:
  • 206 Answers
Most likely the piston (#15) has partially unthreaded from the piston stem (#17) - this requires a complete teardown to rectify. Sometimes it is simply because use has caused it to loosen - it can also be because the piston has stripped.
Also check your bumper - if it is worn, or in pieces the driver will overdrive.
Posted on Apr 17, 2014
5 Suggested Answers
  • 1383 Answers
SOURCE: bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Posted on Nov 25, 2008
  • 52 Answers
SOURCE: the staples don't go in far enough
Either the pioston backed off piston stem or the blade is broken. remove 4 bolts holding shoe to yellow body. remove magazine and shoe. remove yellow bumper inside gun. Pull piston down and inspect blade. if not broken see if piston backed off stem. if so gun must be rebuilt and part # BC347 must be replaced. visit www.bostitch.com and download schematic and where parts can be obtained.
Posted on Feb 14, 2009
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
  • 342 Answers
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Posted on Apr 05, 2010
How to adjust depth on bostich mk111fs
There is no depth adjustment on this tool -
If the staples are going too deep - most likely the piston (#17) has threaded off the driver inside the tool, you have a broken piston bumper (#62) inside, or the teflon foot pad (#56) on the bottom of the tool is the wrong thickness for the flooring you are using.
If the staples are not driving far enough - most likely you have a broken / chipped driver blade (#21) or the teflon foot pad (#56) on the bottom of the tool is the wrong thickness for the flooring you are using.
Detail
Sep 01, 2014 | Stanley Bostitch MIIIFN Flooring Nailers
My paslode air framing nailer model 5350-90s is loosing air out of the trigger valve when I press on the trigger and the nail does not fire. What is the problem ?
Sounds like a bad O ring. There are rebuild kits you can get with a new set of O rings. Or you can have it done for about $30-50.
Jun 09, 2011 | Heavy Duty Stanley Bostich Heavy-duty...
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
My bostich flooring staler wont fully drive every staple and it is getting wors....it is not leaking air
Your compressor needs to be checked first. There is an air pressure regulator on most machines - be sure all is in working order. It might help to be sure you're playing any lubricants in the stapler configuration as well.
Nov 05, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
I am using this product for a hardwood floor. I cannot seem to get the staples driven in far enough. I'm using 2" 15 gauge staples and have oiled and set the regulator correctly
the wood may be to hard for the gun to drive the stapel right in or you may just have a worn out gun,,turn the regulater up some more to increase the guns power a little more it should hit the stapels a bit harder then,,,some wood is harder than others,,dont just go by what the book sayes! if it works,,,use your setting not what the book sayes, only back it off a bit if it berrys the stapel a foot beep in the wood!!!
Jul 31, 2010 | Campbell Hausfeld CHN50399 2in1 Flooring...
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
The staples don't go in far enough
Feb 12, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
I AM HAVING TROUBLE OUT OF MY BOSTITCH MIIIFS FLOOR NAILER
D Farley,
I repair these nailers all the time. Anytime the nail or staple is bending you have 2 causes. Either the stapler has a broken blade, the magazine is loose on the foot gate, or you are shooting into plywood over concrete. that is allowing the staple to hit the cement subfloor. Use 11 /2" staples on 3/4" wood floor over 3/4" plywood when over concrete.
Dec 16, 2008 | Stanley Bostitch MIIIFN Flooring Nailers
Bostich nail gun plumger not retracting
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
Nov 27, 2008 | Heavy Duty Stanley Bostich Heavy-duty...
Stanley Bostitch MIIIFN Flooring Nailers Logo
93 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
