Question about HP Pavilion dv6000z Notebook
When the power button of the system is pressed the indicator on the charging port flickers and goes off and the system would not power.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
The power cord light flickers and when pressing power button power symbol lights and goes out.
This indicates one of your charger, battery or power cord damaged, just check laptop is getting power or not,
probably this may be causes by defective charger or power cord,
Thank you,
please rate me if you are happy with this..
Sep 04, 2011 | HP CompaqPresario CQ61310USE Notebook
My controllers wont sync to the ps3 or charge on it but they charge when i plug them into the PC. i had the "Maximum power reached" message thing plop up then my ps3 crashed and now they dont...
yea i have noticed my ps3 isn't charging stuff either it only does charge when its turned on im pretty sure theres a setting to charge while the ps3 is off To sync:
  • Connect the USB cable (provided with the controller) into the data USB port on the top of the controller. Insert the other end of the controller into one of the two USB ports on the front of the system.
  • Power on the television and the Sony PlayStation 3. You are going to see a series of lights flicker on the top of the wireless controller.
  • Press the PS3 button in the middle of the controller. This tells the gaming system it is connected. A single light appears on the controller.
  • Remove the gaming controller from the PS3. You can now use it wireless. It is also possible to remove the USB cable from the PlayStation if it is blocking your field of view.
  • Jan 15, 2011 | Video Game Consoles & Games
    Cannot set time @ date for Ohsen watch...AD0721...thanks
    (A=LIGHT,B=MODE,C=START,D=RESET)
    1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
    2.How to view date? Standar time indication, press C "month/ date" indication.
    3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
    4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
    5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
    6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
    7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
    8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
    9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
    Nov 30, 2010 | Watches
    We had to order a new headset (ear piece) to our CS70 system. Do we need to program it? It is not picking up the handset.
    To pair another headset to the same base, you must first enable the multi-shift
    pairing feature. Long press (5 sec.) the speaking volume minor adjust up button on
    back of base until the power indicator light flashes.
    2. Place a charged headset in charging cradle and red indicator light on base will flash
    for 2 seconds if the multi-shift pairing feature is enabled. Within 10 seconds of
    doing so, press either the "+" or "-" listening volume button for 3 seconds until the
    headset talk indicator lights to indicate pairing mode, and goes out after successful
    pairing. Repeat steps
    Jul 11, 2010 | Plantronics CS70 Wireless Headset
    Lenovo Ideapad Y510 won't turn on or off
    try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
    Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
    Laptop will not charge, lead/cable is fine, i think there is something wrong with the port the lead goes into. Before it stopped charging completely the charge light was flickering indicating charging was...
    This sounds like the power jack is damaged, which is a common fault, it will most likely mean the complete removal of the motherboard if you say what model the laptop is I might be able to write you a strip down procedure.
    It is simple enough to solder in a new power jack it’s getting at it.
    You should be able to get a replacement for about £3.
    Feb 17, 2010 | Computers & Internet
    How do i got my gps on eiglish when we buy we turned on it goes on on rare lenguage we prefer einglish or spanish
    hi tc75,
    plug it in and let it charge for awhile using a know good charger, like the car charger. it has a indicator light to let you know its charging.
    now press and hold the power button for up to ten seconds until it starts. if that fails
    this is a very common problem for the models listed below.
    the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
    you can get help to repaired it, here
    or buy the port here
    if you need further help, just let me know.
    bill
    Nov 29, 2009 | Tomtom GO GPS Receiver
    Supertooth one user manual
    Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
    Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
    Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
    To pair with your mobile phone:
    1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
    To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
    To end a call: Press red button for 1 second
    To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
    To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
    Hope this helps.
    Nov 22, 2008 | Cell Phones
    Power goes off when booting ...
    Hi if you had not used your notebook for sometime and kept it without charging the batt., then charge the batt fully probably for 12 or 14 hours and then switch it on .
    May 24, 2008 | Fujitsu Siemens Lifebook C2230 Notebook
    Power up problem
    power supply issue. replace power supply
    Jan 08, 2008 | Iwill ZMAX-AP Barebone
    HP Pavilion dv6000z Notebook Logo
    26 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
