Question about Microwave Ovens
My chrome Simplex tea kettle doesn't whistle anymore!! I can hear the rattle when I shake it, but it won't whistle now.
How to get full power from outlet???
If you are getting your microwave to turn on then you are just fine on your outlets. They should be putting out 120v. You just have an under powered Microwave.
Dec 14, 2015 | Microwave Ovens
Fan Ventilation panel on my GE Profile Spacesaver doesn't operate or close now.
For help with louver operation, see the owner's manual and for further help ask here.
Sep 04, 2012 | Microwave Ovens
We have a sunbeam peace and quiet kettle ke7500s it is approx 3months old. When we reboil the water there's always a tainted water taste in the tea and coffee .The taste is so bad we tip out the hot...
As you know friend, some water when it is boiled it really taste bad so I suggest use a water purifier to filter other out dirt, dust, other particles in a water street supply. Sure when you drink the water (not boiled) it doesn't taste bad, that's normal because we can't distinguish it easily. Also try to clean your kettle using baking soda it will eliminate tainted taste.
I hope my advice help you with your problem.
Mar 23, 2011 | Microwave Ovens
The internal base and tea leaf basket are tarnished from the tea. How can I clean them?
"The best tea pots are never scoured clean". Ask any retired tea drinker.The same with tea strainers. It improves the tea flavour to have a clean but not scoured out strainer. Have I saved you a job?
If you still want to and if the items are stainless steel, a scouring pad and washing up water will do it.
Mar 10, 2011 | Microwave Ovens
My tea express is leaking from the area around the bottom of the kettle ? around the join twixt the kettle and the electrical heater element ,what sealent could I apply= Please.MP
Either fit a new neoprene gasket or if you don't mind the flavour, use a heatproof sealant that is sold in many DIY stores.
Dec 23, 2010 | Microwave Ovens
Can I use my enamelized tea kettle on a ceramic cooktop?
you sure can totally safe to use just be careful as ceramic heats up really hot in microwaves
merry christmas
Dec 08, 2010 | Microwave Ovens
I have a Morphy Richards 43678 kettle and i would to know how to switch off the whistle as i have lost my instructions. !! Thank you
I thought the horrible sqwawking noise couldn't be switched off?
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Nov 21, 2010 | Microwave Ovens
I need to clean brown stain and scale (?) from two 'plastic' tea kettles, one a Chefmate, the other a Kitchen Gourmet. The latter is much more stained than the other, with entire interior incuding spout...
If you can find this product: (Or order it online)
el-4.jpg Picture: http://www.sanishieldproducts.com/images/el-4.jpg To find a distributor: 800.528.3149
Shower Tub & Tile Cleaner
  • CLEANS everyday scale, calcium, hard water spots, soap scum & body oils on showers, bathtubs, tile and sinks.
  • EFFECTIVE on glass, fiberglass, clear plastics, ceramics, aluminum, stainless steel, brass, chrome, porcelain and cultured marble surfaces.
  • UNIQUE biodegradable, cherry-scented chemistry. 32 fl. oz. size (950 ml)
ELIMINATE" TUB & TILE CLEANER 32 oz.
  • Non-toxic, non-fuming non-abrasive, non-corrosive, non-flammable
  • Biodegradable
  • Removes soap scum, scale, hard water deposits and body oils
  • Safe on plexiglass, plastic fiberglass, chrome, brass, gold, silver and ceramic
It is carried by Ace Hardware $6.49 ea
An awesome product that you spray on and let sit overnight. then simply wash it off. (Non Toxic / Non corrosive) No gloves required but does have an odd odor so I would let it soak outside. Heavy accumulations may require a second treatment.
Also great on shower heads. Remove it.. place it in a glass overnight and then re-install the next moring. Does not discolor anything. Ditto for shower enclosures and tile. Why this product is not in great demand is a mystery.
Link with picture: http://milo.com/32-oz-eliminate-shower-tub-and-tile-cleaner (out of stock!)
THIS WILL Clean it.
Kelly
Sep 10, 2010 | Microwave Ovens
Microwave Ovens Logo
111 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
