Question about HP Mini 1000 Netbook
I have a HP Mini Netbook. Computer will turn on, but I have just a blank black screen. Help!
  • 109 Answers
First, Remove you battery, your AC adapter and any connected USB or SD cards from your computer. Hold down the power on key for 5 seconds. The put everything back together.
This most likely won't solve the problem but works occasionally.
If that didn't work you will need to create a restore usb key to fixthis error and you will loose any and all of your saved data from the laptop.
This is the only known solution I know to the black boot screen issue.
If you were running Windows on your mini follow these instructions
Download ftp://ftp.hp.com/pub/softlib/software10/COL27307/ob-68017-1/ImageCreator.msi
(Taken from HP support website for accuracy)
"CAUTION: The restore process reformats and completely erases the hard drive on the HP Mini. All the files you have created and any software installed on the device are permanently removed. The restore process reinstalls the original operating system, software, and drivers. Software, drivers, and updates not installed with the factory image must be reinstalled using Update Manager.
To download the files to another computer running Windows and restore your HP Mini, follow these steps:
1. Download and save ImageCreator.msi to the Windows computer.
2. Double-click on ImageCreator.msi and follow the on-screen instructions to install HP MIE Restore Image Creator.
3. Insert a USB flash drive (2 GB minimum) into a USB port on the Windows computer.
CAUTION: The restore process reformats and completely erases the USB flash drive. All the files on the USB flash drive are permanently removed.
4. Launch the HP MIE Restore Image Creator utility from the Start menu.
5. Select "Download HP Mini MIE recovery image", select the target USB flash drive, and click on Start to download the latest HP Mini recovery image from the HP web site. The recovery image will be downloaded and saved to the Windows computer and then written to the USB flash drive.
6. When the download and write process is complete, remove the USB flash drive.
7. Insert the USB flash drive into a USB port on your HP Mini.
8. Change the boot order by turning on or restarting the device, and then pressing F9 while the "F9 = Change Boot Device Order" message is displayed on the screen.
9. Use the arrow keys to select the USB flash drive, and then press enter.
10. Follow the on-screen instructions to install the operating system and programs.
11. After the operating system and programs are installed, remove the USB flash drive.
NOTE: After the operating system and programs are installed, the device will automatically restart. You are then prompted to set up your HP Mini.
12. Restore your personal files and reinstall any updates not installed with the factory image using Update Manager.
13. You can uninstall the HP MIE Restore Image Creator utility from the Windows computer and delete the downloaded recovery image (the image must be deleted manually).
You mini should be back to a fresh operating system
If you were running Linux Download, ftp://ftp.hp.com/pub/softlib/software10/COL27307/ob-68020-1/liveusb-creator-ubuntu_0.3.3netbook0dennis5_all.deb
To download the files to another computer running Ubuntu Linux and restore your HP Mini, follow these steps:
1. Download and save liveusb-creator-ubuntu_0.3.3netbook0dennis5_all.deb to the Linux computer.
2. Install liveusb-creator-ubuntu_0.3.3netbook0dennis5_all.deb on the Linux computer.
3. Insert a USB flash drive (2 GB minimum) into a USB port on the Linux computer.
4. Open a terminal window and enter the following command: sudo liveusb-creator
5. Select "Download restore image" / "HP MIE Restore Image", select the Target Device, and click on Start to download the latest HP Mini recovery image from the HP web site. The recovery image will be downloaded and saved to the Linux computer and then written to the USB flash drive.
13. You can uninstall the HP MIE Restore Image Creator utility from the Linux computer and delete the downloaded recovery image (the image must be deleted manually).
Posted on Sep 11, 2010
I have a Windows Hp 1000 Mini & The Screen does not turn on it remains black & blank. I've gotten the tip that I must reinstall the Operating System on it. But Does anyone have any Idea ho
Almost all of the HPs Mini laptop screen issues are related to the internal video card/motherboard. hopefully you still have the laptop under warranty.
www.linkedin/in/diaztech
twitter.com/diaztech
www.diaztech.com
May 16, 2012 | HP Mini 1000 Netbook
I have an hp mini 1000 model 1121nr notebook i had a problem with the size of the window and went in to control panel and obviously did something wrong because after i did that when i turned it on it...
if you can see anything while you were restarting your notebook may be your vga (display)has broken, but if you still can read and you can go to safe mode by pressing f8 and then enter a vga mode
May 11, 2011 | HP Mini 1000 Netbook
My hp mini, has a blank screen after it shows the the pages of actually being turned on
You may have a problem with either your video card or your inverter. Please let me know if I can be of more assistance to you
Mar 27, 2011 | HP Mini 1000 Netbook
I can't access windows on my hp mini. I just get a blank screen
Blank as in black?
Do you have power?
Remove any usb devices and then try and start it.
if that doesn't work, disconnect the unit from power and remove the battery. Wait 30 seconds. Put in the battery and power up.
Jan 02, 2011 | HP Mini 1000 Netbook
I have an HP Mini 110. I have turned off the
Try this: Remove Mini from A/C power; remove battery. Hold power button for 10 seconds; reinstall battery & A/C power. Try starting normally. Your netbook doesn't appear to have an external VGA port, or I would suggest trying to connect to an external monitor. Your monitor back-light may be burned out.
Mar 10, 2010 | HP Pavilion ze2000 Notebook
Hp mini screen is blank
Hello imlapd. If you don't even see words on the screen when you first turn it on (the BIOS puts things on the screen before it boots to Windows), then there are 2 possible causes. First, the video output or something else on the motherboard is bad. Second, the LCD display (the laptop screen) has failed. The cost to fix either one of these will be close to what the laptop cost brand new if not more. The good news is, if your HP Mini is less than a year old or you got an extended warranty, HP will fix it for free. You just have to call their customer service.
800-HP invent
or
800-474-6836
Be prepared to provide the following information: Serial Number (S/N), product name, model number, and a brief description of the issue.
Aug 26, 2009 | HP Mini 1000 Netbook
Hp mini 1000 - no startup display
you got error this windows/OS system so u need to re-install the OS/Windows..good luck and have nice day
Jun 18, 2009 | HP Mini 1000 Netbook
Hp mini wont start
i had a similar problem. this made my netbook start again. turn off your netbook and then remove the battery. then (with the battery still out) slide the power switch into the on-position and hold it there for a minute. then reinsert the battery and turn on your netbook. as soon as it turns on, keep repeatedly pressing the F10 key till you see your screen light up. then login normally and go to the hp site and download the driver for your netbook. i think its under BIOS? hope this helped. sorry if it didnt...
Apr 08, 2009 | HP Mini 1000 Netbook
HP Mini 1000 Netbook Logo
474 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
