Question about LG Televison & Video
Need a code for a 37LH2000 MODLE LG TV to put into a SKY remote contol
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
  • 899 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
SOURCE: trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Posted on Feb 18, 2009
SOURCE: need sky remote code for 37lh3000 lg tv please
Sky remote code for LG LH3000 is 0206. This works for the 37" and the 42" and probably for a plethora of other sizes.
Posted on Mar 18, 2010
thewylds2
  • 10 Answers
SOURCE: Need a code so that i can operate my LG tv. model
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Posted on Apr 25, 2010
Need a remote contol code for sony bravia kdl 37U4000 for skyplus HD remote control
Hello
Remote codes for Sony TV with Sky Plus remote are:
038
533
679
505
533 038 039 064 102 130 505
Ok.
Jul 06, 2011 | Sony BRAVIA KDL-37U4000 37 in. LCD TV
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
What is the TV setup codes for LG TVs for the SKY remote?
Here are the codes for LG TVs for the sky remote.
Codes provided by SKY:
0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318, 0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367.
Codes provided by LG:
0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851
Regards,
sjstore2
Dec 18, 2010 | Televison & Video
I need the code to program my sky plus remote to my new lg tv it is an lg 42pq300
press intreactive on sky remote move down to sky costomer service press select then move down to program remote ( 5 ) you will need make ( lg ) and model number of tv then follow on screen instructions
hope this helps
Nov 28, 2009 | LG 42PQ30 42 in. Plasma TV
SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
Sky remote
Dear folks,
Not sure if you still need the answer but the code is 1174. I have tried it and it works -
have TV and SKY on press TV on remote
press red button and Select together until the red light on the remote flashes twice
enter the code
press the SKY button
It works!!
Aug 01, 2008 | Televison & Video
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sky remote code for lg 37lc46
for sky plus remote ver 8 the code four number is 0206
the three number code is 206
Nov 16, 2007 | Televison & Video
Codes
halfmoon your tv code is 0154 . Need modle #'s for the others sory
Sep 25, 2007 | Televison & Video
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
70 people viewed this question
Computer Repairing
Computer Repairing
