Question about Janome Memory Craft 4000 Sewing Machine
I need a replacement Foot F No 822804004 for my memory craft MC4000
  • 161 Answers
Try ebay as people often sell their spare feet when they upgrade
Posted on Sep 12, 2010
Will a memory craft 4000 work without a foot pedal
Most machines require some sort of foot or knee pedal. There are, of course, treadle machines that you actually "pump" with your feet. There are also hand-crank machines available. Some of the newer machines that have a free motion capability can be set to stitch only when the fabric is moved under the lens, however, that is probably best only for free motion quilting and not for actually stitching seams, etc.
If your machine is lacking the foot pedal, check to see if a replacement can be found. Frequently, a sewing repair shop can either locate a generic or wire one for your machine.
Here's a manual for your machine:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0ahUKEwi-uNjQq5PLAhUC6mMKHfDkBDgQFghGMAc&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fretired%2Fcomputer%2Finst-book-mc4000.pdf&usg=AFQjCNHXP9z7dWGFaVchzjicsdfYtEBAEA
Feb 25, 2016 | Janome Memory Craft 4000 Sewing Machine
I have a memory craft 9000 and it has just started sewing by itself..........HELP what can I do??
When it starts sewing by itself, unplug the foot control. If it stops sewing, then the problem is in the foot control.
May 03, 2011 | Janome Memory Craft 9000 Computerized...
Can't figure out automatic buttonhole use on MC4000
2 things must do:
You have to use the buttonhole foot.
You have to pull down the lever to the lowest position (just left of needle bar/ presser bar up in machine.)
Set to buttonhole. After each buttonhole, be sure to change off the buttonhole then reset to buttonhole to reset the buttonhole to the beginning
Mar 15, 2009 | Janome Memory Craft 4000 Sewing Machine
I need a new Motherboard for my MC4000. Where can I find one?
Try here, https://www.sewingpartsonline.com/janome-mc4000-sewing-machine-parts.aspx or try Janome them self .
Mar 07, 2018 | Janome Memory Craft 4000 Sewing Machine
Quilting on Janome MC 4000
I have a MC4000 and a manual. To raise or drop the feed dog, remove the accessory box and feel at the back of the free arm there is a lever that will slide left or right to raise or lower the feed dog. I am not a quilter, but the manual says to use foot A (zigzag foot) and accessory L (quilter) which appears to be a guide. Cheers, Deb, Townsville, Australia
Aug 16, 2008 | Janome Memory Craft 4000 Sewing Machine
Stops sewing
Sounds like the motor is stressing and a cut-off is operating to protect from overheating........ensure the bobbin area under the needle plate is clean and clear of lint, and that there is no thread jammed around in this area, also at the take-up arm and the cams at the far left of the upper shaftnear the needlearm.........if there is thread wrapped around anything, unwind it VERY CAREFULLY .....DO NOT pull and break it, be patient and move the handwheel gently in reverse while gripping the trapped thread, working it free slowly.
Of course it may be that the motor is old and needing a replacement, but as this machine is quite elderly and may have other complicating issues, you would be best to have someone take a look at it for the best decision of fix or replace, if it comes to that point.
May 13, 2008 | Janome Memory Craft 4000 Sewing Machine
Replacing light bulb on mc4000
takes a special bulb which costs around $10 U.S. Easy to change Just pull out and reinsert in proper position.
Sewman7
Apr 28, 2008 | Janome Memory Craft 4000 Sewing Machine
How to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Jun 21, 2007 | Janome Memory Craft 4000 Sewing Machine
Sewing Machines Logo
47 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
