Question about Maytag Washing Machines
I have a Maytag Performa washer that will not spin all the water out. What could be the problem? It does spin some.
  • Maytag Master
  • 19,396 Answers
Hi.
Check the drain hose connected to the pump. If the machine is a front load this should be accessed from a door on the lower front side of the machine. On other models the pump is accessible from back or underneat the machine.
If the machine completes the cycle but does not drain completely, more than the pump the likely responsiblem is the pressure switch. This is the device that detects the water level and is supposed to stop drain when there is no more water.
The pressure switch is difficult to test. Since it is an inexpensive device it is usually replaced. Before replacement try blowing into and cleaning the hose connected to the pressure switch.
The door latch must also be tested. In some case the door latch may interrupt right in the middle of the spin cycle. This happens because of vibrations opening a defective door latch switch.
From your broad description, the cause is most likely the pressure switch.
Posted on Sep 11, 2010
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
IUs very loud during spin cycle and you would
It appears Maytag no longer produces the type of quality product we have purchased since 1970... we've owned three Maytag Washers - our last "performa" is a piece of ****!
Dec 23, 2009 | Maytag Performa PAV2200
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Maytag performa series washer
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
May 28, 2008 | Maytag Performa PAV2200
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
