Question about GE GSS25JFM Side by Side Refrigerator
Back wall of frezzer covered with snow, removed cover, coils frozen over with ice. have to de-frost freezer every 3-4 wks. Model#: GSL22JFTA BS
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
First the refrigerator portion lost cooling but the freezer was fine over time the freezer esentially turned into a refrigerator. It is no longer making ice or keeping things frozen, but is about as cool...
the evaporator coil is frozen over and cant release cold air due to this,defrost the unit remove rear panel inside freezer and troubleshoot the defrost heater and thermostat and also make sure the fan near this coil is running, on the evaporator coil as,you cant blow cold air thru a coil covered by ice
Jul 02, 2011 | Jenn-Air JSD2789GES Side by Side...
Tip
How to stop top freezer from ice ing up on (frost free) fridge HOT POINT
i recently had the problem of my freezer ice ing up on my " HOTPOINT" 18cu" fridge. i kept taking everything out and manualy de-frosting it. i got so frustrated doing this every 3-5 days so i did this : Behind the plastic cover at the back there is a coil. attached to this coil is a round silver part with wires attached to it. it is somekind of temperature sensor. this was the culprit.. here is wat i did to fix my problem.. : FIRST " UNPLUG FRIDGE" !! remove all contents, remove both BOTTOM AND TOP PLASTIC COVERS, if coil is all ice, thaw with hair dryer, if not iced up look for a SILVER , ROUND, sensor approxamately 3\4" high by 1" across. <----{ this sort of looks like a plastic bottle cap.. }CUT WIRES as close to this sensor as possible. REMOVE from coil tube.it will just pull off of coil. take care not to damage this coil or tube in the process.. with this sensor removed , just use yellow or orange wire nut and put these wires TOGETHER and attach wire nut and wrap electrical tape around wire nut and wire. put plastic covers back into place, put all contents back into freezer, plug fridge back in.. " D O N E ". its been 4months now and fridge and FREEZER work better then ever... this fix cost me $0.00 i can't get photo into here. sorry.. this process takes about 10 to 30 minutes to complete..
on Jan 10, 2010 | Refrigerators
The fridge been loosing it cooling and freezing ability over a period of a week, the seals are in good condition and it has no other problems.
what's the brand name,model number and how old is it.if everything is running good but it's not cooling like it used to you could have a leak in the sealed system.the best way to tell is to remove the inside back wall of the freezer,look at the evap coil,if the frost pattern isn't even throughout the coil you have a leak,if there's frost just at the top of the coil and not covering the whole coil it's time for a new machine.is there any like ice or snow on the inside back wall of the freezer?if so you have a defrost problem and this would happen,also if it's a g.e. you could have a bad motor board,you need to send the brand name model number and let me know if you find frost building up in the freezer or what you see
Feb 22, 2011 | Refrigerators
RFA52 upright fridge freezer keeps frosting up.what is the 'normal' setting for the freezer 0 or 1?
Setting should be midrange. If the freezer is frosting on the back panel you have a defrost problem. The coils will be iced over and the unit will slow down on it's cooling. If there is frost you will need to deice the coils by removing the frezzer back wall panel and use a hair dryer to melt all of the ice. The problem causer of all this will be either the defrost timer, defrost t-stat or defrost heater. Good luck.
Feb 28, 2010 | Freezers
GE Frig GSL22JFTA BS
If you get water at the bottom of the door then something is blocking it between there and the dispenser. Usually ice. Leave the door open and cover the freezer opening with a blanket to keep freezer cold.It should thaw in 156 or 20 minutes.
Oct 08, 2009 | Refrigerators
Frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kennmore model 253
Unplug the unit, open the freezer door and look through the vents at the bottom of the back wall. With enough light you should see the alluminum coil through the vents. If there is ice/frost in the vents your coils are frozen up. Remove the cover on the inside back wall of the freezer you may need to remove the ice maker as well if you have one it just plugs into the back wall there is also a plug behind the cover to the back upper left corner. Once the cove is out of the way use a hair dryer to defrost the coils or leave the unit unpluged for a while. After all the ice is gone reinstall the cover and turn the unit on it will probably work for 3-10 days and then the process must be repaeted again. I replaced the defrost thermostat on mine 2 weeks ago and all is good so far. The defrost thermostat is a little round device that snaps onto the small copper line in the upper right corner behind back cover it has 2 blue wires and cost's about $20.
Hope this helps
Oct 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Ice in bottom of frost free freezer
the heaters to defrost the coil may not be working
Jun 24, 2008 | Maytag MSD2454G Side by Side Refrigerator
Freezer has layer of frost on back wall - refrigerator not working
Defrost circuit problem, the snow means that your freezer coil is not being automatically defrosted. This could be a problem with the defrost heaters or defrost timer. Also in the newer models a module
controls this operation. Call for service. Removing ice or snow from the back wall is not the solution. The coil behind the back wall is also frozen and no air is circulating.
May 15, 2008 | Maytag 22.1 cu. ft. Bottom Freezer...
GE GSS25JFM Side by Side Refrigerator Logo
273 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
