Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbowmate brush wont move - Rainbow E series Canister Wet/Dry Vacuum
Brush wont move and its not the belt
If the belt is not broken, most likely the brush roller needs replacing. If the brush roller turns freely then it is likely the pulley on the motor that drives the belt.
Oct 03, 2014 | Proteam ProForce® 1500XP Bagged Vacuum
Dyson brush not turning?
The brush wont move it is quite often that your belt has snapped you can get them from any good hoover outlet or order on li
Jul 23, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Cleaning brushes wont rotate
I understand how important the brushes are when cleaning.
You may want to the check the pump belt for breakage for the brush belt and pump belt work in conjunction with the pump.
If you're still experiencing difficulty, you may want to have your machine inspected at one of our Authorized Service Centers. Here's a quick link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 17, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
The brush on ours wont spin
Take out the brush roller. (turn the plastic lock mechanism with a coin or screwdriver, pull out the plastic holder, and the brush will pop out). The brush roller has two white caps on the ends. Chances are, one or both of these caps have moved out just a bit, putting too much force on the delicate motor. Simply push the caps back firmly into place. Make sure the brush and the surrounding area is clean, put back in and It should spin .
Feb 25, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The brushes move freely by hand but wont spin
It could be the clutch that causing your problems. What you should do is take it to a repair shop and have it looked at and see if that's the problem.
Aug 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brushes wont turn on shampooer
Dear Momneville
I have the same steamcleaner and had the same problem, I took mine apart a found a clog between the turbine and the wheel that the turbine moves by vacuum when it gets glogged there is no vacuum to move the wheel. If you are not mechanically inclined in suggest you do not take it apart unless you think you can get it back together properly.
Hope this helps
ahill_1
Dec 24, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover brushes wont turn
Is the shaft on the brush block or did it break off, if it did, replace the brush block. On the top, left rear corner is a lever that moves baack or forward depending on the handle being upright or tilted back for usuage. Is it moving? If not then you have a problem there. Otherwise if the square hole doesn't move when it is turned on, and the lever is switch to the on position, then replace the turbine.
Jul 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Eureka the boss the brush wont go around
Hey there scrappy13, I would suggest you unplug the unit, turn it upside down and remove the bottom plate uncovering the brush assembly. Inside there should be a belt which drives the spinner brush. If that is in tact, then the brush itself may have been unseated when you pulled the rug out. It should be obvious to find the correct placement. Reseat, ensuring the belt is attached properly to the motor as well as the brush. If the belt has broken, a replacement is available at a registered repair facility. Good Luck!
Jan 29, 2008 | Vacuums
Brushes not spinning after change out
I got my brushes spinning by moving them while the unit was running. For mine it seems that they got stuck from sitting. The brushes move from the air driven motor unit. This works from the vacumm that is being put through the machine. I just spun the brushes while the unit was turned on. Don't get your fingers caught.
Oct 26, 2007 | Hoover F5906-900 Upright Steam Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
41 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
