Question about HP G60-235DX Notebook
Display is not vsible in hp G60-235DX - HP G60-235DX Notebook
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 18, 2010
Screen frame broke
Screen frame being the Display Bezel.
http://h10032.www1.hp.com/ctg/Manual/c01573159.pdf
With the laptop closed, the top cover is the Display Enclosure.
Is it broken also?
http://www.lapzone.com/servlet/the-54572/HP-Pavilion-G70-17-dsh-inch/Detail
Can you say OUCH! That's the cheapest I found, but it was a quick search. Hopefully you'll have better luck in searching.
The HP part number, for the Display Bezel of the HP G70 series, is;
HP 488386-001
The HP part number for the Display Enclosure is;
HP 488379-001
Base Enclosure;
With built-in modem, Digital Media slot, AND -> with HDMI port,
HP 489114-001,
http://www.impactcomputers.com/489114-001.html
Base Enclosure:
WITH built-in modem, Digital Media slot, and NO -> HDMI port,
HP 501252-001,
http://www.ebay.com/itm/ORIGINAL-COMPAQ-CQ70-Case-Bottom-Covers-501252-001-Grade-A-/330628933816?pt=LH_DefaultDomain_0&hash=item4cfb0528b8
Hinge Kit; (2 each Hinges),
HP 488384-001,
http://battery-adapter.com/product_info.php/products_id/3900/vSPS:+488384-001
You have more damage than just the Display Bezel, I feel.
Access what damage you have, and I'll step by step guide you in replacing.
Just post back in a Comment.
Regards,
joecoolvette
Jan 29, 2013 | HP G70-250us Notebook
Having trouble connecting to internet
Observe the device structures at the location of recognisable malfunctions. For example ascertain that computers cable or wirless connectivity components are intact least encounted vsible obstructions. Usually computers that derive internet connectivity via vables either phone lines ethernet should be observed for structure kit disconnections either as accendatals or encounted a condition requiring restoration. Second, attempt to logon the network as verification since experincing malfunction. usually the network structure of signals would have times out either as idleness resolution or likely encountered a condtion requirig disconnection. Manually power off the devices that provid internet connectivety to acquire recognfiguaration especilly with durational netowrked structures cause sluggishness or disconnects automaticallly. once least capable of acquiring the user experinces requires to contact either by telephone the network establshiment to verify the conditon. Once any malfunctiobs were encounted from the alternate network structures would be made aware to revive restorations.
Feb 18, 2011 | Computers & Internet
HP cm1312nfi control-panel display WHITE, it still...
Try doing a hard or reset or nvram:
1. Turn the printer off, disconnect the phone line
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If the lcd does not display anything contact hp or a local service provider as there is a definite power failure.
Al
Eliteprintersolutions@gmail.com
May 20, 2010 | HP LaserJet CM1312 All-In-One Printer
There is no display on my HP Pav dv9000
Is there any display during start up? If so, then the possible solution is that the display has been toggled for TV or external monitor display. Try hitting Function F5 on the keyboard (default display toggle function) and see if that turns on your LCD display.
Dec 31, 2008 | HP Pavilion dv9000z Notebook
My computer wont open
Hi woc169! Your problem may be related to an HP recall/repair announcement regarding left side hinge defects. Go to http://www.hp.com/#Support or call the number at the end of this message. Hope this helps!
HP Limited Service Enhancement for Left Display Hinge
HP has identified a hardware issue with certain HP Pavilion dv9000, dv9100, dv9200 and dv9400 series notebook PCs.
Step 3: Identify the symptoms Ifyour computer’s product number is listed above, and the notebook PCexperiences one or more of the symptoms listed below, contact HP duringthe Duration of the HP Limited Service Enhancement to determine whetheryou are eligible for a free repair. Symptoms of a broken left display hinge include but may not be limited to the following:
  • Whenopening or closing the display panel, you may hear popping or cracklingsounds from the bottom left corner of the display (left hinge area).
  • When opening or closing the display, the display may feel loose or wobble in the lower left corner.
  • The plastics surrounding the left display hinge may show cracks or breaks.
Service enhancements and free shipping
NOTE: This HP Limited Service Enhancement program is available in the United States and Canada through May 31, 2009.
  • Free shipping Ifyour notebook needs to be returned to HP for repair, the shipping costsare free. HP will immediately send you a postage paid container inwhich to send in your computer, and we will pay the return shipping. AfterHP receives your notebook PC, HP will use its best efforts to repairand ship your notebook to you within 10 to 14 business days.
  • Post-service warranty The HP repair warranty covers the left hinge repair for 90 days after HP returns your notebook PC.
Contacting HP To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
Installing hp pos pole display
Download the HP Pole Display Windows OPOS package (sp42198) which will install both the Windows drivers for the device and the OPOS drivers for the device.
The following is the Windows Device Manager screenshot after all the drivers are loaded for the HP USB Pole Display:
NOTE : The COM port number might be different on customer's unit.
Note: The pole display driver will automatically assign the next available virtual port in the system.
HP Pole Display Setup Software Utility
Download sp41532 - HP USB Line Display Configuration Utility from HP website.
Run the file and the Utility will come up as shown below
The COM Port would always be COM1.
Change the selection to the COM port listed in the Device Manager of the unit.
Click on the Welcome Message Tab and Change the Text and Click on “Write to Pole Display
Now the text should be displayed on the Pole Display.
Nov 22, 2008 | POS X POS-X Black Pole Display w/ Serial...
Roper washing machine
It's direct drive. It may have a bad coupler. Did you see any black particles under washer? Also look for oil on floor and bottom of washer. Transmission can leak oil into clutch causing slow spin.
Nov 11, 2007 | Washing Machines
HP G60-235DX Notebook Logo
421 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
