Turn off the printer + unplug from power socket.
Leave for 30 seconds.
Plug in and turn on printer. The error should be gone.
Let me know how it goes.
The 15H error means: XFER BELT:Incorrect pressure by or separation from the transfer belt cleaner
It's a serious repair and may cost more than replacing the print.
Step
1. Check PC9 (position sensor 9) operation
2. Replace the belt cleaner pressure/separation mechanisms
3. Check SL4 (solenoid 4) operation
4. Replace PWB-A (Master board)
5. Relpace PWB-B (Controller control board)
How can I locate PC9, Belt Cleaner Pressure Separation Mechanisms,
SOURCE: magicolor 2530dl
IF YOU LOOK AT THE PRINTER FROM THE TONER BOTTLE END THERE IS A SMALL CLUTCH IN THE TOP LEFTHAND REAR CORNER OF THE PRINTER.
YOU WILL NEED TO REMOVE THE TOP COVER TO ACCESS IT.
IT IS BEHIND A PLATE BUT FASTENED TO THE MAIN FRAME OF THE PRINTER.
YOU NEED TO SPRAY INTO IT WITH SOME LUBRICANT LIKE WD40 NOT OIL.
THIS CLUTCH GOES RUSTY AND DRIVES THE CAROUSELL SO GIVES 15H CAUROSELL ERROR
