Question about Black & Decker String Trimmer Cordless 12" 18V
I have an electric Black & Decker GL550 Reflex trimmer and was wondering how I remove the head to attach a universal head to it?
3 Suggested Answers
SOURCE: how can i repace the
Instructions can be found at: https://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gl550_uk.pdf.
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
Posted on Jun 11, 2008
SOURCE: Black & Decker gh1000 trimmer head not spinning
The same thing happened to me. You either have a ruined belt pulley, or, hopefully, the belt burned out. Belts are easy to find online, but the housing is tricky to remove - see other posts.
I finally got it the plastic housing apart on my trimmer (there is one screw hidden under the label), only to find a total meltdown. The plastic pulley is ruined, and the only way to get it replaced is to buy a new motor (the most expensive part).
If your trimmer is no longer under warranty, then you can get a refurbished gh1000 for the price a new motor unit.
Posted on Jul 26, 2009
How to remove the head. String has wrapped around it and it wont turn
I use a dental pick to get the end of string where I can pull it out the way it went in . saves a lot of tear down time
Oct 02, 2014 | Black & Decker Black and Decker & Grass...
Black and Decker electric trimmer (grass hog) model GH600...eats thru line, one spool lasts about 3 minutes
It sounds like that the automatic line release is damaged.
1. Remove and clean all debris from the head. I assume that you have already done this if you have changed the line a few times, but just make sure.
2. Remove the the head from the shaft.
3. There should be a large spring in there. If its broken, damaged or missing that will allow the head to spool line pretty fast. again make sure all debris is removed from this area.
4. Check the feed dogs in the same area as the spring. If they are worn the same problem will occur.
5. Install line on the spool.Make sure that it is wound the proper direction. There should be arrows indicating this. The line wound in reverse will also cause the same problem as well.
6. Put it all back together and see if works now.
7. If this doesn't solve it you may need to replace the head assembly.
Jul 02, 2011 | Black & Decker Black and Decker & Grass...
CST2000 can't get the battery off when pushing the two release buttons.
Black & Decker didn't make it easy to remove the battery pack. You have to push both buttons in at the same time, while pushing the battery pack forward. It takes a little while to get good at it -- you have to hold onto the trimmer with the same hand that's pushing the buttons in, while pushing the head forward with the other hand.
If you're only taking the head off to charge the battery, you can charge it while it's still attached. The hole for the adapter is on the back of the head, so you can plug it in while it's attached to the trimmer.
Hope that helps!
Jun 17, 2010 | Black & Decker String Trimmer Cordless 12"...
St1000/type 1 grass/weed trimmer - How do I remove the head?
Yes, there should be a lock hole on the base of the bump head, spin around until both holes align and stick a pin through them both and the base will be locked.
Now spin the head off.
The new one will come with adapters if you need them.
Jun 14, 2010 | Black & Decker String Trimmer Cordless 12"...
Describe your Black & Decker
You have missed a screw about half way, there is one under a sticker.
Sep 03, 2009 | Black & Decker 14" Grass Hog Xp...
How do I rethread the cutting line on a black and decker strimmer reflex plus
take the spool out there shood be a I hole to push the twine throu tie a not that wont come out look for dirtion or arrow to wind it leave enough to sitck thru the side where the twine cuts push the spool up and lock it
Jul 27, 2008 | Black & Decker String Trimmer Cordless 12"...
How can i repace the line on a black & decker strimmer gl550
Apr 20, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
263 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
