Question about Whirlpool Refrigerators
My refrigderator made a loud noise continuosly for about 30mins and since then dose not get cold again, only the freezer compartment gets a bit cold but not cold enough to form ice.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice built up and stopped the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
What is a lifter and where dose it located when i start it make a lot noise for 30mins and stop then start again
Because the lifter leaks down when the engine is cold and then pumps up later tells me that the lifter is faulty and needs to be replaced. I would recommend using someone who is qualified for the job. This isn't a skill level D job.
Apr 25, 2014 | 2005 Kia Sedona
There is a loud vibration noise whenever the compressor is running. Everything, including the coils on the back of the box vibrates so loudly that it can be heard in the next room. The compressor appears...
Is the evaporator coils froze up? Sounds like maybe the compressor is getting liquid back to the compressor or the compressor is running real high head pressure. Also check and see if the compressor is mounted on springs or pads.. Make sure all of the refrigeration lines are not bent and causeing vibriation.
Dec 19, 2010 | Kenmore Refrigerators
My freezer compartment is making a loud vibrating noise. The ice maker is not working, the water freezes on the inlet ramp to the cube maker. What gives?
The vibration is usually an unballance, check the freezer fan blade for any broken pieces. The water freeze will cause the Ice maker to not work..if the fill valve for the ice maker leaks, even a small bit it will freeze up on that "inlet ramp" if so, replace the fill valve. Else, I've found a unit not used, left alone for a week or more.. that tube still freezes up...gets too cold?
Oct 24, 2009 | Frigidaire Refrigerators
Freezer cold- Fridge Not, Loud Noise
that is the damper door malfunctioning this open to allow cold air into the fridge compartment the damper needs to be replaced
Sep 20, 2009 | Frigidaire FRT17G4B Top Freezer...
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
The fridge compartment not getting any cold air.
Well for whatever reason the fridge compartment is now getting cold air again and its all working fine. Have no idea whats gone on with it but is working again hahaha. The only thing that we did was take the back off the freezer, where it houses the fan motor, the motor wasnt quite straight so I straightened it and now its working. Whether that was the problem to begin with I have no idea.
Apr 12, 2009 | Westinghouse Refrigerators
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dacor refridgerator model # ef488dcbss
Air flow from freezer to fridge box may be obstructed, ck for free flow there, no big steaks in the way of air to lower unit, or may be set too cold. Thats all i got for now, try it.
May 14, 2017 | Refrigerators
Refrigerators Logo
75 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
