Question about Pentair 460736 Master Temp Pool Heater 400btu ()
My system is short cycling. the unit fires and begins fine, yhen after about 90 seconds the service heater light comes on. the service heater light remains on for about 60 seconds then the unit goes back to heatingfor about 90 seconds. the process just keeps repeating
rcampsr
  • 90 Answers
SOURCE: Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Posted on Apr 20, 2009
wiredlocal22
SOURCE: Minimax NT cycles on, Flame
I had the same problem and it was the ignition mod after i replaced that it ran fine again .
Posted on Jun 01, 2009
  • 990 Answers
SOURCE: Startup cycle goes fine. All lights(power,
If you are getting fire and have an eo5 this is a reading for no flame so it is not reading the flame. What you probally have is small spider webs in your burner orfaces. You will need to pull the burners out and with a small wire or the like clear the gas orfaces going to the burners. These little webs can divert the gas to the main burners and keep it from the burner that reads the flame. Your heater will come on with a big woosh as the gas needs to come from other burners to fire. I hope this helps. Good luck
Posted on Nov 28, 2009
  • 990 Answers
SOURCE: pool heater seems to fire,
It's not reading the flame. This could be many things. If you have an electronic ignition you will find a wire going down to the front of the firewall to just above where the burners go into it. It connects to a piece that has one screw holding it and that goes through the wall and into the burner box. If you pull the tray and inspect the burner just below it their may be soot or something keeping the flame from getting to this probe. If the wire from the probe is grounding any where of if it got rat chewed this can cause this problem. Follow this wire to the top of the heater and make sure it is securely fastened to the ignition control on the terminal that says sense. It could be these problems or the ignition control box may have gone bad (ooo! noo! $$$) At two years old I would think sooted burners or a bad wire. Also when you have the tray out you can remove the orfaces that feed the gas to the tray and check for spider webs. The orfaces unscrew with I believe a 3\8 wrench,(I could be wrong) Start with the one under the probe. These webs will look like tiny cotton balls and you can clean them by blowing out or with a tooth pic. I live in Phoenix and this is not a problem in the desert but in many places it is. So if you don't live in a desert this could be a good place to start also. Good luck
Posted on Oct 17, 2010
adamh294
  • 310 Answers
SOURCE: I have a mastertemp 250k
Yes, yo cannot "dry fire" a water heater. There are several safety measures in place to prevent this. If you were to successfully "dry fire" your pool heater, you would most likely have to rebuild it again.
Posted on Aug 04, 2011
Does your oil light suppose to come. on when u try to start your 1987 dakota
yes
the oil light should show up till you get oil pressure which is after cranking for a few seconds or the engine starts
Jan 01, 2017 | Cars & Trucks
MasterTemp 200 cycles every 30 seconds
since you already replaced the thermisto next would be the control board
Apr 18, 2014 | Pentair Pool & Spa
The heater is causing interference with my Satellite TV signal reception. When I turn on the heater my signal begins ti digitize then it goes out. what can I do to prevent this I have the baseboard heater...
sounds like the heater might have a bad heating element or the transformer inside the unit is shorting out. first thing that I would check is to remove the wire plate and check for any burned out wires. ( this unit could be a serious fire hazard ) --- you could always have a electrician come out and check the unit for voltage problems or for about the same price you could go down to your local Hardware/appliance store and just buy a new unit and replace it,, they install very easy and it only takes about 30 minutes to remove and replace the unit --- try and get a unit with the same messurments so you will not have to paint the wall area around the new unit.
now one more quick test to trouble shoot the unit --- try and run power to your satellite system via a extention cord and a different outlet from inside the house. there is a chance that the sat system and the baseboard heater are sharing the same power source and when the heater kicks on ( with its problem ) it is causing a issue with the sat system.
again,,, check out and solve this problem soon as it could lead to a electrical fire.
c...
Jan 30, 2011 | Lasko 5620 Electric Baseboard Heater
My central heating unit is in the attic of my 2bd/2bth house. I don't know its age. It's a gas unit, but doesn't have a constant pilot flame. Rather, the pilot is ignited electronically. The problem is...
You don't mention make or model so here is my guess as to how to thinkout the trouble of what ever is in your attic.
For some reason, your heater is mis-firing. Normally, I would expect 3 to 5 such events at which time the heater goes out on safety. The heater knows it is on safety but you don't until it gets cold in your house. When you turn the power off, wait the 30 seconds, turn it back on, the heater no longer knows it is on safety (memory cleared) so it fires. Your heater continues to fire until ? at which time it starts counting again to 3 or some number. At the max mis-fire number - it goes out on safety again ... repeat - turn it off, wait 30 seconds, turn it back on - no memory and so forth.
Do you have a service contract or regular service man? Might be time to find one.
Thanks for your question at FixYa.com
Jan 05, 2010 | Heating & Cooling
Startup cycle goes fine. All lights(power, pressure, thermostat, and heater) sequence correctly. After ignition, heater fires up(seen through viewing window) but then blows out 15 seconds later when fan...
Nov 24, 2009 | Pentair MINIMAX NT TSI IGNITER
Minimax NT 400 TSI Heater problem
I bet that your 15 seconds of flame are more like 7 seconds. The time is very important. If the flame is not recognized after a specific time the valve is shut off. If the flame sensor is GOING bad but still make some rectification then you may get the issue you are having. I would start with the flame sensor and work from there.
May 03, 2017 | Pentair MINIMAX NT TSI IGNITER
Fan cycles on every few minutes.There is no demand and the burner doesn't come on but the exhaust fan cycles on for a few seconds every couple of minutes.
You're most likely getting a pressure wave (spike) that is generating momentary flow across the flow sensor. The heater is registering this "instant" flow and beginning its firing sequence. Once the flow dissipates, the unit then goes into a purge cycle. I'd recommend having your water pressure tested to make sure it isn't abnormally high (above 60 psi) or abnormally low (below 30 psi). Assuming the pressure is normal, you can use a pressure reducing valve or pressure regulator to absorb the spikes and stop the unit from cycling.
Aug 12, 2009 | Noritz Water Heaters
Apr 20, 2009 | Pentair Mastertemp Heater
Pentair 460736 Master Temp Pool Heater 400btu () Logo
60 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
