Question about LG 22" FLATRON LCD Monitor
My lg l194wts keeps switen on and off not a lead problem
How to dry washing mashine
You have to get at the heating coil at the back of the unit. Clip your VOM meter leads to each terminal, set it at at least 250V. Turn the timer on, plug it in, push the start button and see if you have 220V at the terminals, if you do the element is shot, replace it. Many times its as simple as looking inspecting the element for any breaks. If its broken it will be obvious. When you are doing the voltage test keep your hands off the machine, just in case!
Aug 13, 2014 | LG Washing Machines
I have a LG HDD DVD recorder which was given to me without any instructions. How do I plug it into the LG sound system and then the TV? I have 2 yellow white red leads and 1 red and white lead.
the red led i thingk is for recording,, light is power on,,, used rca audio output to connect to your lg.... or digital optic ouput... vidoe out to your tv video in
May 30, 2011 | LG RH177 DVD Recorder/HDD Recorder
Monitor keeps going green lead between tv and monitor when moved slightly rectifies problem
Try unplugging the lead at both ends and back in.
If this does not work get a new lead and try that.
There is a possibility that the connector on it is faulty but a new lead is a quick way to find out.
Feb 06, 2011 | LG MZ-42PZ14 42 in. Plasma Television
I have a LG CF360 with a blank screen. Is there a way to access the files to transfer to my new one (through computer) by USB without being able to see the screen? I have photos, videos, and audio I want...
Hi, yes this can all be done with no problems, all you need to do is get the lead that connects your phone to the computer and you will also need a copy of lg pc suite, once you have this installed you will be able to save it all on your computer with no problems.
to get lg pc suite all you need to do is use google and search for lg pc suite, then when you hit search the top one in the list should be the lg site and this would be the safest one to use once you have downloaded this all you need to do is connect your phone to the computer then go into the program lg pc suite and it will then let you transfer everything from your phone onto your computer.
now the problem with your phone is a very common one with all flip and slide phones its also a common problem for laptops,netbooks,portable dvd players basically anything where the screen moves has or will get the problem you are having with your phone.
now the problem is to do with a data ribbon that connects the screen to the circuit board in the bottom half of the phone, this ribbon is really thin and has several single strand copper wires running through now when you keep opening and closing the phone it causes the ribbon and wires to become brittle and they then break giving you the problem you are now getting, the part itself is cheap to buy and cheap to have fitted so if you wanted to keep the phone then that is something that can be done.
you dont need to see the screen to transfer anything from your phone to the computer as long as you have the lead and the lg pc suite then it can be done using the computer and you can then back everything up that way.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 15, 2010 | LG CF360 Cell Phone
Lg flatron 22 inch keeps switching its self on an off repeatedly ..its not the leads its the tv ...tried a friends monitor with my leads ..no problems
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 10, 2010 | LG 22" FLATRON LCD Monitor
If I turn on the tv (lg 3000 lcd), picture appears only for a few seconds and then it goes black. Can you please tell me, what could be wrong?
Check your Scart leads and connectors, possibly one of the leads is loose or maybe faulty, change a scart lead over to see if this will cure it.
Apr 28, 2010 | LG 32lg300c 32 in. LCD TV
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
LG `21` INCH TV
If it has been moved or bumped recently the sound you are hearing is the main HT lead that has been displaced. TGhis is a blasck lead with a rubber disk surround at its end that fits into the picture tube. Do not touch without turning TV Off and using rubber gloves to reinsert.
Please rate our help to keep us online
Aug 24, 2009 | JVC AV-48WP30 48" Rear Projection...
LG 22" FLATRON LCD Monitor Logo
106 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
