Question about Heartland 3110 Top Freezer Refrigerator
Model 3000/3100 Top Freezer Refrigerator. To replace gaskets which are split on the top and bottom of refrigerator door--order time and price as well as company in our area to handle installation of gaskets if not a do-it-yourself project?
Subzero refrigerator/freezer, model 590. Door gaskets replaced last year, but it still ices up in top front of freezer? Any ideas?
Ice or frost in the freezer can be caused by one of Three issues:
    • An improperly closed door.
    • Improper ventilation of the freezer.
    • The Ice Maker Flap.
    1. Door Not Closed Properly
    • Make sure that the freezer door closes completely.
    • Make sure that the door gaskets are attached properly to the door and that they are clean. Also, make sure they are sealing properly and are not torn or split.
    Take a dollar bill and close it in the door. If you can pull the dollar out with no resistance, the seals should be replaced.
    • Make sure there are no packages resting against the rear wall of the freezer.
2. Improper Ventilation
    • Space your food out as much as possible to improve ventilation.
    • Make sure that the air vent in the freezer is not blocked.
    Refrigerator Compartment
    If your refrigerator is freezing food, the temperature is set too low. Raise the temperature a few degrees to fix the problem.
    If your refrigerator temperature is too high, condensation may build up and freeze on the bottom of the refrigerator. Lower the temperature a few degrees to fix the problem.
Dec 06, 2016 | Refrigerators
How do i replace a top freezer door gasket
Hey friend, thank you for your post!
On a top mount Frigidaire refrigerator the gasket is a magnetic strip which should be able to be easily removed. You would have to order a new gasket for your refrigerator which you should be able to reach out to the manufacture for part number and availability.
If you need any additional assistance with replacing the gasket I would recommend reaching out to a professional for proper replacement. Hopefully this information is helpful. -Matt
Oct 04, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Ge pfs22mi door gasket
This is going to be tricky so watch the video and tell me if the answer to you question comes out and resolved by the tricks revealed in the below video.. Sea Breeze
When you say latch can you tell me the part number of the latch you say that you need replaced? Here is a link to the parts you are describing HERE
GE Profile French door bottom freezer Model # PFS22MISBWW Door Gasket and related parts
Apr 01, 2013 | GE Profile Bottom-Freezer Refrigerator...
Freezer door does not close tightly,, I feel cold air coming from around seal between it and refrigerator door.....
check to see if door is warped. twist door to change the 'warp' to make it shut better. if the seal is cracked or split.. look up model, check prices on the internet..order one from a local appliance store ( NOT from big box store) if, after you have frustrated yourself to the point of throwing the refrigerator away, then call the appliance store to have them put it in.. they will be somewhat sympathetic since you bought the gasket from them and if you didn't tear it up.. they'll give you a decent price for the service call. :-)
Dec 26, 2010 | KitchenAid KSRG25FKSS Side by Side...
The freezer door on my top-mount no-frost refrigerator comes open every time you shut the bottom door. What is the problem????? Before I purchase another brand...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Dec 26, 2010 | GE (GTS16BBS) Top Freezer Refrigerator
Refrigerator does not get cold. Freezer does. 3.5 cf.
check the eoor gasket it may need to be replaced. The door may be out of line(not closign snug) you may have to lossen the screws holding the gasket on and line the door. a hint hold the bottom of the door with your leg or foot and **** lightly on the top of the door. That how we do a quick adjust
Apr 21, 2010 | Frigidaire FRT17G4B Top Freezer...
I am finding water on the top shelve of the refrigerator as well as under the vegetable bins. Is there something I can do or is it time for a new refrigerator? Not sure that is the model number, had this...
The water is probably condensation. If you are in a humid area and the refrigerator is opened and closed often the humidity in the air will condense on the cool surfaces of the shelves and sides and will run down to the bottom of the refrigerator. If it is very old the door gasket may be deteriorated and leaking air into the refrigerator. Check it by closing the door with a dollar bill sticking out. If you can pull the bill out easily when the door is closed the gasket should be replaced.
Oct 29, 2009 | Amana ATB1832AR Top Freezer Refrigerator
I have a top freezer. Whenever the refrigerator door is closed, the freezer door pops open. There appears to be a good seal around each door... How do I keep the freezer door from poping open, when...
Replace the seals. It may appear to be in good shape but what is happening is the compressed air from closing the refer door is going up and releasing the seal on the freezer I would replace the freezer seal first as that should solve your problem.
Thx
Deathstalker
Aug 22, 2009 | GE PTS22LHR Top Freezer Refrigerator
Condensation on refrigerator front btwn top freezer and refrigerator doors
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Oct 01, 2008 | Frigidaire FRT18B4A Top Freezer...
Heartland 3110 Top Freezer Refrigerator Logo
217 people viewed this question
Top Heartland Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Heartland Refrigerator Expert? Answer questions, earn points and help others
