Question about Rainbow 75th Anniversary Canister Vacuum
I replaced the powerhead drive belt. Now (2 times) while vacuuming the powerhead motor appears to run backwards. Because the metal pully which has left hand threads on it will backout / unscrew it self. Prior to this belt rerplacement it functioned properly. Thank You Bob
    Scholar:
  • 41 Answers
Look at your power head motor. If you see a fiberglass looking sleeve on the shaft where the belt attaches to it, you need to remove that. You can slip it off, chip it off, or break it off piece by piece. You can usually use pliers and break it into pieced until you get it all off. It could also have a metal sleeve or a plastic or rubber sleeve on it. You will be able to tell if it has any sleeve on it. If it does remove what ever sleeve that it has. Tighten the brushroll pulley snugly tight. That should do it.
If you have any more questions, let me know,
Ralph
Posted on Sep 13, 2010
I have a Lindhaus powerhead MOD.PB12e SN123463. The powerhead turns on and the roller starts turning but after a couple of seconds it starts sounding like something is not letting the roller turn properly...
A common problem is for hair to get wrapped around and forced into the end bearings which causes the motor to work harder or drive belt to slip. Cleaning the hair out can be a short term fix but new bearings might be needed. It's also a good idea to replace the drive belt at the same time as the slipping belt is probably not going to perform well even with new bearings.
Mar 03, 2015 | Lindhaus Vacuums
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
Belt for heritage 2
remove power head turn knob on front counter clockwise look in hole on back of powerhead make sure belt is on the hook install powerhead back on motor turn knob clockwise
Jun 22, 2009 | Kirby Heritage II Vacuum
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Powerhead on rainbow not working
If the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
If it stops working as soon as you release the button - you need a new circuit breaker. If Motor in the nozzle works but brush does not spin - you have to replace the belt.
Good Luck
Nov 20, 2008 | Rainbow 75th Anniversary Canister Vacuum
Power brush motor seems too weak
This machine needs a new belt. The belt is stretched into position and even if it is not used, will fatigue over time. This can occur as the machine is in storage waiting to be sold. If you check the bristle on the roller, you will observe that it extends out the bottom of the powerhead quite far and is very stiff. This causes the brush to engage the carpet very aggressively and puts considerable strain on the belt. A tired belt will fail very quickly under these conditions. You should take it to a warranty depot and have the belt changed.
This machine also has variable speed motor in the main unit. This is so you can adjust how heavily the powerhead brushes the carpet. If it is set too high, on certain carpets, the suction will pull the powerhead down too hard and this will bogg the roller and cause the belt to fail prematurely.
Feb 02, 2008 | Hoover S3765-040 WindTunnel Bagless...
Powerhead woes
You should not use this powerhead on any natural or oriental fibre carpet. If you check the brush roller, you will see that the bristle extends out the bottom of the powerhead quite far and that the bristle is very stiff. This is o.k. for synthetic carpets, but will be too aggressive on natural carpet. It will pull material out of the carpet and eventually thin it out. You should use a passive air turbo or a carpet tool for this rug.
As far as the belt is concerned, if it is over a year old, it is due to be replaced. Old belts are stretched and will come off because they are worn out. You might also check to make sure the motor is in place correctly. It is very common that when people want to check the inside of the powerhead, they commonly remove the three screws that secure the motor, thinking that these screws will open the powerhead. If you observe the area between the screws, you will notice that there is a "no screwdriver" warning there. The four screws for the hood are recessed and not as obvious as the motor screws, so this mistake happens quite a bit.
Jan 01, 2008 | Hoover S3755 WindTunnel Bagless Canister...
G2000 Kirby HELP
I'm not familiar with this type of vacuum, but if it's like most kirby's the powerhead gets all its motion off the tapered spindle underneath the powerhead. IF the belt is installed backwards on this spindle then all motions are reversed. there should be an arrow stamped into the blower housing. the belt should be installed so it is nearest to the arrow in the direction of the arrow on the housing.
Aug 22, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Rainbow 75th Anniversary Canister Vacuum Logo
65 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
