Question about Samsung Refrigerators
I have a samsung srl551dp after about 8 hrs after turning on today it stopped colling and digital display for freezer started to flash
5 Suggested Answers
tborn6
  • 700 Answers
SOURCE: fregerator not cooling
check out the refrierator defrost sensor for the refrigerator side. the connection may not be making a good contact. open up the refrigerator evap section and behind the lights for the crisper is the connections. be carefull because the evap may be frozen up and the styrofoam wil break if its frozen up. thaw it out first with a shop vac blowing air out.
Posted on Mar 07, 2009
SOURCE: Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
SOURCE: Samsung twin cooling fridge/freezer model
http://www.whitegoodshelp.co.uk/wordpress/samsung-rs21-and-rs60-range-fridge-freezers-recall-potential-fire-risk/
Posted on Dec 06, 2010
heatman101
  • 43501 Answers
SOURCE: SAMSUNG MODEL RL43WCIS FRIDGE
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Rs253baww stopped working
Stinkerbelle, im not sure i understood your problem,
You are sayint it is freezing the food, when it is not in the freezer?
Jan 02, 2008 | Samsung RS2534 Side by Side Refrigerator
Flashing freezer led
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
Nov 02, 2013 | Samsung RS2630SH Side by Side Refrigerator
Samsung cooltech needs reset to keep cooling
HI.JAMES. shot in the dark.it might work for a quick cheap fix.ok 1-get a 24 hour ac plug in timer.plug fridge into it.set timer to run for 4 hours and off for 10 minutes.it might work.let me know if it does.better then PCBs and sensors etc.good luck.ali
Jun 19, 2012 | Refrigerators
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Hi, I have Samsung freeze model No SRL551DP >both freeze and freezer. is not working.both has light, it flashes. If I turn main switches on and off it works again for four hours freeze and...
check the evaporator how much frost build up. if it build up block air way. the heat element or defrost thermostat is bad . otherway check the condensor make sure clean
Jan 10, 2011 | Refrigerators
Samsung RL33SBNS fridge control panel
Hello!
Please check the control panel instruction of the manual: http://manualsbrain.com/en/manuals/1290306/?page=8
Jul 21, 2017 | Samsung Refrigerators
SRL551DP, fridge stops, display on door flashing.
You most likely have a problem in the freezing/cooling circuit. Check your condenser, evaporator fans to see if they are running okay. Most likely it may be the condenser fan.
Dec 17, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
87 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
