Question about Canon PowerShot SD200 / IXUS 30 Digital Camera
Will the canon ixus 30 use a 8GB SDHC memory card, as it shows card locked in display
    Brigadier General:
  • 3,006 Answers
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Posted on Oct 06, 2010
Canon ixus 700 memory capacity
The IXUS 700 works with SD and MMC cards, 2GB and smaller. It will not work with higher-capacity SDHC cards.
Mar 31, 2013 | Canon PowerShot SD500 / IXUS 700 Digital...
The IXUS 700 works with MMC and SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards.
My canon digital camera ixus 75 card is locked how to procedure to unlock
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Why does display read MEMORY CARD ERROR CARD IS LOCKED!
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Oct 29, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera canon ixus 105 memory card error
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 05, 2011 | Canon PowerShot SD1300 IS IXUS 105...
How should I do to open card locked Canon IXUS 65
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 19, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
The camera will only work witha 1GB memory card, we have tried to install a 5GB memory card and the camera shows "memory card error" yet when we try to install the same memory card in another...
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. Anything over 2GB is SDHC.
Nov 25, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon IXUS 95 IS gives me a report: card locked, while the card is not locked; gives me a report; memory card error please tell me what is wrong?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out (note, this is not the problem with your newer model camera). Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Oct 15, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
I got a new 4gb sd memcard for my 2005 canon ixus 50, screen shows " memory card error" "card locked". tried switch on card as u suggested, no diff.
The IXUS 50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 06, 2010 | Canon Cameras
Will my canon ixus 60 take a 16gb memory card
Yes. The IXUS 60 was designed to work with SD cards. Cards larger than 2GB are actually SDHC (the HC stands for High Capacity) and will not work in this camera.
Jul 12, 2010 | Canon Cameras
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
565 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
