Question about Maytag Neptune MDE5500AY Electric Dryer
Drum turns but motor humms - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 3,053 Answers
Hello, jack I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Drum wont turn just humms
Open the door and check of the Tub spins freely, if so then you have a bad motor and if it does not you could have an object stuck in the blower wheel which is attached to the motor and prevents it from spinning
Jan 22, 2016 | Dryers
Why does my maytag dryer when turned on get red hot instantly, yet the motor only humms?
quit buying parts ur motor is shot and u should be or soon be smelling a wireish burning smell.
Oct 08, 2014 | Maytag Dryers
My front end load dryer makes a humming noise when started then goes to pause
Have you checked the drying drum to see if it spins freely? Open the door and verify it spins freely. if it does then the motor may just be in a bad spot. usually after spinning the drum a turn or two it will get it running. it humms and clicks because of the motor not turning and trips an thermal overload switch and you have to wait for it to reset. Now if the drum dosent turn then you have a problem with drum rollers or something stuck in the way of the drum.
Dec 06, 2013 | Frigidaire Dryers
When I turn knob to on, dryer just humms and i smell a burning smell. what could be the problem?
Hello
Obviously from what you describe, the drum is not turning.Most likely the drum belt is burning against motor pulley or idler pulley( most likely broken). If it were burning electric smell that would indicate motor under duress.If the dryer is full ,empty it and try again. You could have overloaded.If same result you'll have to open her up and check belt ,pulley and motor.
All fixable
Good luck
Feedback greatly appreciated1
Jul 28, 2011 | Kitchen Ranges
When i go to start my dryer model # aeq6700fso all it does is make a buzzing sound no heat and drum does not turn? i checked the belt is fine and motor spins freely by hand
If the motor is hummming or buzzzing it most likly the motor or a bad wire conection to the motor.
you can try to turn the drum by hand and retry to start the machine.. if this does work, you have a bad spot on the motor and if it does not and you can verify the noise is coming from the motor then the motor is most likley bad.
Oct 06, 2010 | Frigidaire Affinity AEQ6000WH Dryer
I have a frigidaire dryer. The motor humms but the drum does not turn. The belt is not off the drum.
a humming (shaking) motor means the coils have lost there magnetic feild (replace the motor) and it will work fine
please remember to rank this post
thanks
Jun 21, 2010 | Dryers
Dryer humms but does not turn unless I rotate drum when turned on
HI. This is a damaged sator assembly in the motor casing. the cooper windings are damaged. this motor will need to be replaced asap, if possible.
Oct 19, 2009 | Dryers
Drum won't turn , belt is not broken or off track it humms when power button is pushed
The motor capacitor has failed. It's on the motor under a small cover. Replace it.
Sep 26, 2009 | Whirlpool GEW9250 Electric Dryer
Model#GLEQ642AS2
If the drum is not turning and the hum is a nice quiet hum, then the belt on the drum has broken. The hum you hear is the motor turning without the belt.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Aug 17, 2009 | Frigidaire GLER341A Electric Dryer
Amana Dryer
sounds like a bad motor or something stuck in blower fan.. see if you can maually turn the drier drum if so motor is bad if not something is binding up drum or blower fan.
Nov 03, 2007 | Amana DLE330RAW Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
27 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
