Question about Philips 42PF9631D 42 in. Plasma Television
Philips 42pf9631d/37 - screen is blank LED stays green for 10-15 seconds then blinks red 7 times then 2 second blanks blinks red 7 times and repeats. What could be the problem and is there a way to reset so that this goes away?
  • 395 Answers
SOURCE: Philips 42PF7320A/37 won't power up Led blinks 7 times
go with SSB first cost $595.00 + S/H + core $250.00 the SSB requires special set up to the panel's ID codes a tech should do this if you attempt it your self you'll end up with no display or poor picture.
Posted on Jan 03, 2008
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
I had the same issue with 2 of these sets. It ended up being 2 capacitors were bad on the power supply. They are located towards the bottom of the board, you can visually see they were buldging and leaking slightly. I replaced them with 2 I salvaged out of an old computer (of same values) and the tv works as it did before.
Posted on Jan 08, 2009
  • 1694 Answers
SOURCE: Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Usually, LJ92- numbers made by Samsung have the best price....
Replace both drivers & Y-main at the same time...........T.
Posted on Feb 16, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
