Question about Brother MFC 420CN All-In-One InkJet Printer
Can I print in only black if one of my color ink cartridges is empty?
  • 3 Answers
Yes, you can! You just need to paint your empty cartridge with a black sharpie, one of the side of the cartridge that points out of the printer where you can see ink level.
Or, get a black tape and stick a piece inside of the empty space in the cartridge slot without the cartridge. Again it's a narrow vertical side closest to the edge.Can I print in only black if one of my color ink - 4c8b63e.jpg
It will be seen by the sensor as the cartridge is not empty.
Posted on Sep 11, 2010
  • Iamdoctor Sep 11, 2010
    I actually use a piece of white scotch, but I think black conduct tape is the best.
ESP 7250 Not printing the gray color on the test page
Not much to go on. If you mean the black cartridge is not giving any ink, and the printer does not say the cartridge is empty you still have a problem. But it is possible to solve.
If I'm guessing right, remove the cartridge with the black ink and look in the printhead. You see the little pipe sticking up, where the black ink is going in. with a dropper, just do a few drops of cleaning fluid on that pipe and replace the cartridge. Than let the printer print some black pages, till the black ink is coming through.
It also could be the cartridge with the black ink is empty or dried. If you shake (take care you will spray ink if you don't seal the ink outlet) and you don't hear any ink in the cartridge, unless what the computer or printer thinks it still is empty.
Jan 25, 2014 | Cameras
WITH THE LEXMARK X2250 ALL-IN-ONE PRINTER CAN I USE THE COLOR INK CARTRIDGE TO PRINT BLACK, IF MY BLACK CARTRIDGE IS EMPTY? HOW CAN I DO THIS?
when your black cartridge goes empty , the printer automatically goes into the reserve mode where it mix up the colors in the color cartridge to produce black color
Aug 06, 2012 | Lexmark X2250 All-In-One InkJet Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Can't print when there's only black ink
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
Jan 11, 2008 | Xerox DocuPrint M750 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
219 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
