My pc is pen iii is using window 98, i remove the disc and upgrade it in another pc with xp.i put it (disc) back in my system, but is not booting
  • Computers & ... Master
  • 27,725 Answers
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Posted on Sep 11, 2010
How to install windows xp in sony vaio vgn-nw270F? tia
hello,
I will explain the process for you.
First of all if your computer has some windows like windows 98 or older than you can install the windows by simply inserting the disc and choosing the drive and install the windows.
However if you do not have any windows installed on your system or you have windows installed later than windows xp and want to install another operating system than use the following method.
First of all,
Please make sure you set the boot-priority first.
- you can go into bios by pressing the F12 or ESC key on your keyboard or if the key is different keep in mind when you turn your computer on you should see a small line at the first blink of your screen telling you to press a key to go to bios.
- Thank once you are in the bios please check the boot section and there set the boot-priority and by setting i mean the dvd drive or the cd drive should be apprering on the first section which means that your computer should boot from cd or dvd so that it can read your disc before it reads your hard-disk. remember to change this setting back once you have installed the windows.
- please insert the windows xp disc.
- than press enter on the bios screen and save changes and exit
- you comptuer will restart and
- it will take you straight to the point from where you can install windows using simple few clicks you just have to enter the serial number and your name etc. and the rest computer will do it-self.
Please let me know if there is anything else i can help you with.
Thank you.
May 18, 2010 | Sony XP Pro Upgrade - VS-E85-00087 Upgrade...
How to reformat back to windows vista ?
You need a windows Vista disc. Insert the disc and follow the prompts. I would format the hard drive instead of upgrading do a new install. The best way would be to go into your bios and make sure the boot device order has the cd-rom booting before the hard drive. Then put the disc in and start the computer, when it says press any key to boot from cd hit any key and let it load and then follow the prompts to install.
Nov 27, 2009 | NEC Versa VX Notebook
Hi i am trying to upgrade my window 98 to window 7 but explorer won't let me download it how can i upgrade my computer to window 7
:L You Cant Upgrade From WIndows 98 To Windows 7 Your Pc is too old and The hardware is Gonna be outta date
Nov 16, 2009 | Microsoft Windows 98 for PC
HOW DO YOU INSTALL A SECOND OS ON A SLAVE DRIVE. I AM RUNNING WINDOWS XP HOME EDITION. I WANT TO INSTALL WINDOWS 98 SECOND EDITION ON A SLAVE DRIVE DISC. SOME PROGRAMS I HAVE WILL NOT WORK ON XP.
You cannot install 98 directly on your system slave drive, but there is a way to install it.
1) disconnect your primary drive
2) make your slave drive as primary.
3) install 98
4) Connect your actual primary drive again and start your system
XP records your mac id of your motherboard and 98 does not records, the other way is, you can install both the OPS on your one primary drive by creating different partitions, you will need to full format your drive first.
1) Full format your primary drive.
2) Create partitions.
3) Install 98.
4) Install XP in different drive of your same hard disk
You will be able to see both your OPS when you start your system.
Sep 18, 2009 | Computers & Internet
My transcend usb pen drive D33193 is not working
If you are using Windows 98, it's an obsolete Operating System and virtually nothing supports it anymore. Upgrade to XP if you can. Otherwise, you will constantly run into problems like this.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Microsoft Windows 98 for PC
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
PEN Drive in Case of Windows 98
did you copy an installation of win98 to your pendrive and you want to boot it from there? check your bios/pc setup settings if it supports boot from USB,
May 12, 2008 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Problem is there any software driver for pen drive so that my win98 o.s. computer can detect any type or companies pen drive plz tell me
wow, the 90's are a calling... sure their is a roumor of a usb pen driver for win 98' ....
Windows 98, especially in it's second edition (also known as Windows 98SE), handles USB fairly well, however there are no generic/universal mass storage device drivers preinstalled in the operating system, so you will need to install some additional drivers for it. Some manufacturers do however, provide the Windows 98 drivers on CD, others have them available to download, and others simply do not have them available at all!!!!!!!
generic Windows 98SE USB mass storage device drivers:
http://www.technical-assistance.co.uk/drivers/nusb31e.exe
instructions?? :
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager (*carefull)
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
as always good luck! now im going to go back to my windows 95 and play Bioshock on full graphics!! excuse me = )
Oct 13, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
