Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
My Admiral 21.5 cu ft Designer Serie side by side is dripping from the freezer. This will last for 10-15 minutes at times faster than others. This is not a constant drip but it will accumulate to the point where the bottom of the freezer is puddled and at times leak out. I have removed the back pannel to insure no clogs and to make sure all drainage hoses are in the proper place. What may be the solution to fixing this problem?
  • yetz414 Sep 11, 2010
    Thank you the first time i removed the back of the freezer I only checked to insure the drain hoses were attached but I did not run warm water through them. I also didnt know what to look for regarding frost.
    I will follow your steps and advise.
  • 10,515 Answers
This problem occurs commonly when the drain hose for the defrost system becomes clogged. Water that normally drains to the pan under the refrigerator backs up and you find it there.
It is also fairly common. It sometimes indicates that a defrost problem is either developing or exists.
You would remove the back inside wall of the freezer. Find the drain trough, and using a turkey baster filled with hot water squeeze the hot water into the drain. You want it to flow all the way to drain pan under the refrigerator. If is does not, you **** up the water and try again. You repeat this process until the water goes all the way to the pan.
You can also use a 1/4" plastic tube to clear the drain hose and sometimes (depending on the model) you can work up from the drain pan.
While you're back there, you examine the coils -
1. Even light frost on the coils - Good that's the way it's supposed to be.
2. Heavy even frost on the them - Likely defrost problem.
2. Heavy frost/ice in one area - Very Bad - Compressor and/or sealed system problem.
If you get the heavy even frost sign - You manually defrost the entire refrigerator by unplugging it and (if you want to speed it up) using a hair dryer very carefully (don't want to melt any of those plastic parts). After 12 to 24 hours when the refrigerator is back to room temperature you plug it back in.
Then if the refrigerator works correctly for the next 24 to 48 hours the problem is considered a defrost system issue. The problem will return in anywhere from a few days to several months later. Several components would be checked and then replaced depending on what was found during testing.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
  • taran_2005
    taran_2005 Sep 11, 2010
    Thanks for your response!!
    Don't forget to take all precautions. Any query, revert and i would be glad to follow up.
    Hope i helped you.
    PS - Do not forget to accept the solution,if 100% satisfied from my response.
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator FRIDGE VENTS ICING
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 21, 2011 | Admiral 26 cu. ft. Side-By-Side...
I have an older admiral refridgerator, when you open freezer it sounds like water dripping on a hot skillet. I unpluged it, later pluged it back in and wont come on
The sound was water dripping on the defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
The freezer side of my admiral leaks (collects water and it freezes) at the bottowm. then leaks to the floor. what can I do to fix it?
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Oct 29, 2010 | Admiral 26 cu. ft. Side-By-Side...
This is the second time the freezer accumulates water and freezers at the bottom of the freezer section of the Admiral HMG67158, 26.6 cu ft freez/refrig. The coils behind the panel were completely frozen...
unplug unit, remove back panel inside freezer and manually defrost with hair dryer, sounds like you have a defrost problem, check defrost thermostat, defrost heater or defrost timer, defrosting with hair dryer will fix until it freezes up again
Sep 30, 2010 | Admiral Refrigerators
Admiral Designer Series HMG67184 Freezer appears to be working but not cold enough to make ice, ref side does not appear to be cooling. Do not feel heat around doors except after unplugging the unit and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
erew
Aug 17, 2010 | Admiral 26 cu. ft. Side-By-Side...
I today saw two black liquid spots which dripped from my Admiral two door refrigerator.... help!!! The drips seemed thick like oil but they were soluble when water was applied
the black gunge is moss(it grows in condensation)syringe out the drain hole(s)with clorine bleach,(it will gas off in no time and leave no smell)
Jul 29, 2010 | Admiral 26 cu. ft. Side-By-Side...
My admiral designer series model#HMG621860 is leaking water onto the floor from the freezer compartment where is the drain located on this model, I took everything out of the freezer one week ago and could...
Every freezer have a drip collector beneath it. Some times it may be filled completely with water thus causing an overflow. Else, the opening to the collector is being blocked by some ice. Also this problem can happen with aging of the fridge. There is nothing you can do in particular in this case.
Apr 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator freezer not cold
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Is there anything else that makes you think this is a problem.
Sep 11, 2009 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
ADMIRAL 60ADIBSL
You should be able to remove the grille on the bottom front of the frige. Then look underneath for the drip pan. They are made to be pulled straight out for occasional cleaning. Check online instructions for your particular model. Good luck!
Aug 21, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
