Question about Goodman GDS80904BNA Open Flame Heater
Furnace is on for a few minutes then goes off for a few minutes then cycles on again, it keeps cycling this way until it attains set temperature if it does attain it.
  • Goodman Master
  • 2,557 Answers
Check afc is clean at the back, airfilter could be blocked might need new afc
Posted on Sep 11, 2010
I have a Honeywell programmable thermostat and I have central heat and air system. When I set the heat to a temperature above the inside temperature, the heater turns on for a short period of time and then...
I would say that the problem is in the furnace, not the thermostat. The Thermocouple or other temp sensor needs replacing, the sensor that tells the furnace that it is heating. It just keeps turning off and trying again in 3 minutes cycles.
Jan 01, 2015 | Heating & Cooling
Tempstar DC90 pilot light or burner keeps going out. The furnace will run continuously. Even if I turn heat off at the thermostat. I have to kill power at the panel box to get it to shut off. Then I've...
The reset button near the ignitor is a high temperature limit safety switch. When the furnace gets too hot and the manual reset limit switch is tripped, it most likely goes into a 'safe' mode where the gas control is locked out electronically and the blower is made to run continuously to rid the heat exchanger of the excessive heat. This will continue until the reset is pushed and the power is cycled off. It will remain an endless cycle unless the reason for the overtemperature condition is not corrected.
Your furnace 'temperature rise' is getting too high due to a lack of air across the heat exchanger for whatever reason. Some of those reasons could be a restricted air filter or a blower motor that's cycling improperly on its internal winding thermostat. You could also have a dirty air conditioner 'A' coil (evaporator) on top of the furnace restricting the air flow. Nevertheless, you are going to have to have it serviced by a reputable service company's technician to correct what's wrong.
Nov 13, 2014 | Heating & Cooling
My furnace will not reach the desired house temperature in one cycle. It will run for several minutes, shut off, and repeat. It eventually reaches the desired temp but it take a long time and I feel it...
There are a few different reasons for short cycling of a furnace.
1. Inadequate air flow. Not enough air moving through the furnace can cause it to overheat and trip the high temperature limit switch.
check to see that all registers are open and returns are not blocked.
2 Improper heat anticipator setting on thermostat. Some thermostats have a heat anticipator and too low of a setting can cause short cycling.
4 Partially blocked drain hoses. If the condensate backs up into the furnace it can shut the flame off and then when the condensate drains the furnace starts again. Check all drain hoses to make sure they are clear.
These are just some of the possible reasons for short cycling .
Hope this helps.
Dec 26, 2013 | Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
Starting this afternoon: Thermastat was set (Manual) to turn on at 68, display window showed 63 but the furnace was not running. I manually set the turn on temp below 63, then up to 67 and the systrm...
Definitely a thermostat.It has 2 sections.One is a temperature reference section(what temp you want).The other is the temp reading section.If either one is bad,it will do just like you said.Sounds like the reference section is probably bad because it comes on for a couple minutes then shuts down.Since it was fine earlier in the day,I doubt there is anything wrong with the furnace because as you can see,it is temperature related.A furnace problem would be more of no operation at all,even if just dirty or whatever.The thermostat also would be a more common 'fail component' than the board.A suggestion also,both for a car and a house.During the summer,run the heat for 2-3 minutes,just to cycle it occasionally.In winter,run the A/C for 2-3 minutes.Do both perhaps once or twice a month.It helps keep the components,somewhat fresh I guess you would say,because cycling it occasionally helps to keep it going good.Also,if you encounter a problem,you may be able to get it fixed before you really need it.In the meantime,feel free to come on down to FL until it's fixed,we have room,lol.Although it's chilly now,the weekend will be 70's.(sorry)Good luck,Greg
Dec 08, 2010 | Coleman Heating & Cooling
My Miller furnace occasionally stops in mid
If the flame looks good prior to the room air blower starting but becomes unstable when the blower starts, you have a crack or hole in the heat exchanger. I strongly suggest your technician do a test on it to see.
Dec 04, 2009 | Heating & Cooling
Heat temperature issues with Goodman GMP 100-4 furnace
69,000 btuh is adequate for a 12-1400 square foot house.
Otherwise, your thermostat simply tells the furnace to cycle on/off.
If it calls for heat and does not come on, the problem is with switches and relays within the furnace.
Your setting the temp higher only causes the other parts to keep trying until they finally light and heat.
This is based on your information saying it will cycle on and blow cool air--not hot air.
You will have several temperature variations from floor to ceiling.
You probably have ceiling vents as well.
You need a technician to verify the rollout switches, fan relay, inducer fan etc. if the furnace is not firing everytime you call for heat.
Feb 21, 2009 | Goodman CPLE24-1 Air Conditioner
Furnace Blower cycles on & off
check out the fan switch on the unit and make sure that its the correct one. it should cycloe on @ 120 degrees and cycle off around 100 degrees. Someone may have put in a different one and that is not the approve one.
Dec 23, 2008 | Heating & Cooling
Heating & Cooling Logo
107 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
