Question about GE JVM1630 Microwave Oven
Team, I have a GE JVM1630 BK01 Microwave Oven, yesterday after we finished heating up some food we shut the microwave door and it remained running even though it the programed timer ran to zero. We tried pressing stop and opened and closed the door several times, but it still remained running. We finally unplugged it, waited, and when we plugged it back in it began running again even though we did not select an express time or press start. Additionally, the clock timer is not showing any text or numbers it is just blank. Is there a reset button or process that i can conduct on my own? Thoughts?
    Genius:
  • 1,417 Answers
There is no reset button for this type of problem to be properly solve.
this type of problem can be view from two angle here below
1) From the wall power supply connection
2) from the oven wires connection to the panel or unit control
What this could indicate from your explanation is that there has been a bring of wire from the power control connected to the element (heater), what you are to do to solve this problem carefully, is to carefully unscrew the oven then trace the wire from the main power supply down to the control switch (panel or unit) after you most have unplug it from power supply to see if there is any of meant wires around if you are un able to trace any loose/bad wire then couple it back to it position and trace the problem to the main power supply from the wall mean that a partial contact from the wall unscrew it with a screw driver (technician tools )fix it up and then couple it back with this the problem of continuous will be solve.
thank you and thanks for using fixya.
Posted on Sep 11, 2010
Mine is a similar problem - light and fan BOTH stay on when the cooking/heating finishes! The door remains closed and the food/beverage cooks. However, when it's finished the light remains on and the
There are a number of interlock switches that the oven door activates when closed, sometimes one becomes defective causing the main fuse to blow in the microwave or continue to run when time is up.
Nov 11, 2011 | Microwave Ovens
My microwave oven is not heating food
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 07, 2011 | GE JVM1630 Microwave Oven
The oven is not heating the food. All the controls is working, but it is not heating up the items. I tried to warm up a beverge and it didn't warm up. This just happened all of a sudden. Last night it...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 11, 2010 | GE JVM1630 Microwave Oven
Our microwave is no longer heating food. Is there any way to fix this problem or is it time for a new microwave?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkf
Jun 22, 2010 | GE JVM1630 Microwave Oven
Microwave heating for 20-30 minutes with no food. Does not work.
heatman101
hgj
Jun 02, 2010 | GE JVM1630 Microwave Oven
The microwave is making a humming noise as it runs and the food does not get hot.
your high voltage capacitor or diode in the high voltage doubler circuit is open and can't help double the high voltage to operate the magnetron tube to make food heat
May 16, 2010 | GE JVM1630 Microwave Oven
Microwave doesn't heat food, fan runs, lights work, just no heat
Your megaton went out on you. It will cost 150 to repair.
Dec 27, 2009 | GE JVM1630 Microwave Oven
My microwave does not heat up food, it looks ok buy does not heat up at all
Please check your door safety interlock switches. Find them inside on the side opposite the hinge. If they measure open both with the door open and the door closed, they must be replaced. You are looking for one or more micro switches.
These switches are how the device knows whether the door is open or not - forget what YOU know about the door - the device must know the door is closed in order to turn on the heat.
Thanks for your question at FixYa.com
Dec 21, 2009 | GE JVM1630 Microwave Oven
Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1630 Microwave Oven Logo
101 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
