I noticed before I turned my TV on that the screen looked green not black. When I turn on the TV the green light keeps flashing. I know it is not the lamp because I changed it not long ago.
  • 1 more comment
  • Jorene16 Sep 11, 2010
    Sony Grand Wega KF-42WE610
    New Lamp replaced 7/23/10
    I ordered the bulb from Sony warehouse. It is my second bulb so I know it should work.
    Maybe it is just a bad bulb
  • 10,594 Answers
I need model number and brand info of your tv to understand the possible cause of problem to provide you helpful info.
Thanks.
Posted on Sep 11, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Sep 11, 2010
    I'm Sony tech and know what I'm saying.
    If green light keeps flashing but does not turn to red light flashing then it is lamp in your tv that is causing problem.
    Lamp in tv seems reached to end of its working life span and causing this problem or I can say it is clear symptom of weak lamp. Replace lamp in tv to solve its problem, nothing is wrong in tv except lamp.
    When did you replace lamp in tv last time? Was it Sony original lamp that comes with cartridge?
    Thanks.
    Was it Sony original lamp or some aftermarket low price bulb?
    If tv gets other then lamp problem, it will go to standby and red power light will start flashing, that would be hardware problem.
    But tv does not go to standby mode nor red light flash so it is lamp in your tv, if it was Sony original lamp then call the Store and ask for replacement lamp.
    Thanks.
    Yes, it would be bad lamp though it was from Sony warehouse.
    Replace lamp in tv to solve its issue, I'm confident about info given to you.
    Thanks.
    Just a suggestion.
    Unplug tv from wall socket for couple of minutes to get it reset, replug back in and turn it On, this trick might work.
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My lg tv screen is black and wont turn on
Going to be a economic decision---not likely to be a do it yourself repair--consider taking to a shop for a estimate.
You might want to Google the model number with "parts" to see what boards are available and at what cost.
Aug 27, 2012 | LG 32LC2D Television
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
RCA = flyback?
I just posted a reply to you. Its most likely not the flyback causing that symptom.
Oct 05, 2008 | RCA D52W19 52" Rear Projection Television
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
