I have error code E000001-0002 in ir2870 ple give me solution
  • 35 Answers
SOURCE: ImageRunner 2230 Error E000001-0002
getfile.asp?rid=1258 August 31, 2007 getfile.asp?rid=3215 Product : imageRUNNER 2230 / 2270 / 2830 / 2870 / 3025 / 3030 / 3035 / 3045 / 3530 / 3570 / 4570 Title : E001 Error Code That is Not Resetable Error :
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Posted on Nov 09, 2008
Cogz
  • 1326 Answers
SOURCE: Canon Error Code E000001-0002
Did you press additional funcation? You have to in order to get in to service mode. Then go to copier, then funcation, then CLR/ Clear, then ERR, the hit the OK on the display, then turn the main power switch OFF then back ON. It should reset the code, if not you have a problem with the fixing unit.
Posted on Oct 08, 2008
  • 118 Answers
SOURCE: help me with
this error is related to fixing unit problem try this press * with head 2&8* with head on the LCD panel press Copier>function >clear>err> ok Switch off/on the machine or check the main AC supply if it is stable or not. hope this helps
Posted on Aug 11, 2009
SOURCE: i keep getting error codes
i am getting error E000001 -0010
Posted on Mar 06, 2009
canontech
  • 1219 Answers
SOURCE: Hi - We have an error code on a Canon Model 2800 :
E001
0000 The main thermistor detects 250°C or higher.
0001 The main thermistor or the sub thermistor detects overheating (hardware
circuit detection).
0002 The sub thermistor detects about 295°C or higher.
Main cause The fixing film unit is faulty (i.e., the thermistor has a short circuit). The
main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To clear the error, execute the following in service move:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Fixing film unit
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 ?
(short circuit)?
YES: The thermistor has a short circuit. Replace the fixing film unit.
REF.
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
2. Main power supply PCB, DC controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
BUT FIRST: under service mode *28* copier, function, clear , err turn off and on maybe it will work.If it works check that you have good air flow around the copier.
Posted on May 04, 2010
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Error canon ir2870
It is a problem with the LASER unit BD(Beam Detection) mirror. Check the BD mirror connection for any loose connection. if the problem remains, replace the Image Processor board.
Aug 04, 2014 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
ERROR CODE IN IR 7095 EOOO2- 0001
this error refer there is a problem in the fixing unit, check thermistor and clear that error from service mode
Apr 13, 2014 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Error code
errors 230 , 235 and 241 on a 1999 320s mercedes
Jun 05, 2013 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Apr 05, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Error code E000732-0001
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
Jul 01, 2009 | Canon imageRUNNER C3220 Color Copier
760 people viewed this question
k24674
jasbo
jasbo
