Question about Hatco Corporation Compact Electric Booster Water Heater - 18in W x 24in D x 12in H - 208V - 3
I have a Hatco booster heater, and it is 3-phase, and the terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
  • 37 Answers
I beleive that would be fine.the only reason phase would make a difference is if it had a motor in it.If you hook up a three phase mtr and it runs clockwise to make it run counterclockwise all you have to do is switch two of the three legs.If you hook it up 123 ,132,213 it will be fine. just make sure connections are tight and you have a ground.
Posted on Apr 24, 2011
Testimonial: "You guys are great..."
Hatco booster blowing breakers
Copy following link:
http://waterheatertimer.org/Water-heater-is-blowing-breaker.html
Hatco booster heater typically has 2 sets of thermostats and elements located on each end of heater.
Both sides might be controlled by same 60 amp breaker, or the heater might be controlled by two separate 30 amp breakers.
Be sure you have correct wire and breaker.
After reading steps on link above, add comment and say if this is new installation, or older installation that suddenly started throwing breaker.
Apr 08, 2013 | Hatco 208/3 C-12 Compact Booster Water...
Having power at tank element and booster tank
Unclear what question means.
Copy following link for troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Copy following link for wiring water heater elements, single-phase, split-phase, 3-phase:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Nov 03, 2012 | Water Heaters
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
Not working
It has kick the breaker in the fuse box or it has a reset on the unit its self,reset it.if that does not fix the problem,you will have to replace the unit with a new one.
Jan 22, 2011 | Hatco Compact Electric Booster Water...
Does this unit need pre heated water?
yes the unit will need to be fed with hot water to work correctly.It has a rise if you want your rinse 180 then you will need to feed the booster with hotter water if fed with cold water it will not keep up under high demand usage.
Jan 16, 2011 | Hatco Compact Electric Booster Water...
I have a Hatco c-6 and it is set up for 208 volts 3 phase hook up and the terminals are labled 1-2-3 in the heater.. I have 3 phase and the wires are from the 3 phase panel to the heater..the wires are...
Thanks for your reply. The order in which you connect the wires 1-2-3 does not matter, all three terminal block screws will accept any one of the hot wires from the breaker, one hot wire per each terminal screw.
Sep 12, 2010 | Hatco Corporation Compact Electric Booster...
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
We need a new thermostat for a Hatco booster heater dishwasher
Try Rick at Restaurant Parts and More in Ohio. Have model and serial number. He's pretty good at getting stuff like that and he reasonable on prices. I'm in Ga. and I have a 3 day turn around on anything I order from him. He's a straight shooter too. If he can't help you he'll try to find some one who can.
Feb 26, 2009 | Hatco Corporation Compact Electric Booster...
Hatco c 12
hi my name is mark. hi limit safety has a red reset button follow link to instructions to adjust rinse temp to dishmachine. i hope you are not using this unit as a home water heater. http://www.hatcocorp.com/productinfo.nsf/AllDocumentationAttachments/14B2C666CC6F114286257107005AC28E/$File/EBOOSTERM-0406.pdf?OpenElement
Feb 09, 2009 | Hatco Corporation Compact Electric Booster...
With the hatco booster water for automatic dish machine
Under normal and regular operation Hatco recommends that the unit be turned on at all times.
If the booster heater will not be used for an extended period of time or will be exposed to freezing conditions it should be drained to prevent damage to the unit.
Jan 28, 2009 | Water Heaters
Hatco Corporation Compact Electric Booster Water Heater - 18in W x 24in D x 12in H - 208V - 3 Logo
163 people viewed this question
Top Hatco Corporation Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Hatco Corporation Water Heater Expert? Answer questions, earn points and help others
