There should be no reason why this card won't work with Windows 7 32bit, it could be as simple as your Graphics drivers are out of date. I recommend downloading the latest Windows 7 drivers for your card at the Nvidia website.
Just remember graphics RAM and SDRAM are two completely different things so they don't add up.
As far as I know the 8400GS is a 256MB card.
You are just about at the "top of the line" for that motherboard. AGP is now outdated and your board does not support PCI express. The only boost from the video card you can get is a ATI 9800 Pro or equal. Although the 9800 doesn't support shader 3.0. Your memory is also low. Try getting another 1 GB ram. Best bet is a new motherboard with PCIe and 2gb or more ram with at least a video card with 512mb GDDR3 or more.
You do know you can increase your integrated video's memory in the bios. Up to 1GB. (Yes, I know you currently only have 1GB of system memory) but you can kick it up to 128Mb & Vista should still run. Your 1GB system memory is shared with the on-board video card. I'd like you to clean out the PCI-E slot with some cotton swabs & house hold Alcohol. (do not over soak the swabs). Clean the pny's copper contacts as well. Get a really strong flash light & look into the PCI-E slot & look for dust, dirt & check the copper connectors are not bent or twisted. Re-install the PCI-E card & set the bios back to PCI-E. Try again. Even if the system reverts to weird, install the 8400's software & driver. Re-start the system. See if the system runs normal. Also would not hurt to check for Window's updates. After all that, if system does not function normally I suspect there is something wrong with the 8400 card. Good luck & let me know if this has helped. Have a great day.
