Question about Stihl Chainsaw Air Filter Element 028 Chain Saw O28
Chain saw runs great for about 10 Minutes after it gets hot it shuts off. and will not start. nothing completetly dead wait an hour and your good to go for another 10 minutes
    Sergeant:
  • Stihl Expert
  • 417 Answers
Your coil is plagued with an issue known as "heat soak." You need a new one.
Posted on Nov 23, 2013
5 Suggested Answers
  • 42 Answers
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
Posted on May 17, 2009
  • 211 Answers
SOURCE: hot start problem with husqvarna 261 chain saw
hi robert
you need to change the seals
all the best savumihai71
Posted on Aug 23, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Husqvarna 445 chain saw and it does not
Your Manual nor IPL mention an oiler adjustment..
445 IPL (may not be your saw)
Is this the original bar? A longer bar requires more oil and your saw is not equipped to supply it.
http://weborder.husqvarna.com/order_static/doc/USA/2007/I07000/I0701086.pdf
Detail B (Clutch/Drum/Oiler)
We are seeing many of these does not oil/oils to much problems with these no adjustment models. I recommend you contact Husqvarna, there may be an unannounced recall/repair. If they aren't willing to help you consider contacting your Atourney General and the BBB.
Contact Husqvarna here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
It has an outboard clutch, the oil pump is behind it. If you attempt a repair this will be helpful.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I’ve ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
Source for Manual and IPL:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Posted on Nov 24, 2009
dontbother10
  • 2220 Answers
SOURCE: need new chain for remington pole saw, model
It should, I have been on this earth to long for a definate answer. Both saws have 40 drive links, are 3/8s, and a gauge of 0.050. Please verify my findings here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Have you contacted a local saw shop? With your chain as a pattern they can make a replacement in couple of minutes. Inquire by phone about a price you may be pleasantly surprised. Give them Oregon number 91VG040G (low kickback, most likely what your saw is fitted with). If you feel adept you might try a slightly more agressive chain but the odds of kick back increase. HTH
Lou
Posted on Feb 06, 2010
Testimonial: "thanks, chain went on easy, worked great"
2003 gmc yukon xl
Sorry to get your hopes up but I have a similar problem with my 2005 Yukon Denali. How long does the truck stay running before it shuts down? Mine started out with short spurts of the truck shutting down while driving. It slowly progressed to the point where it will only run for about 45 seconds. Originally the truck would sputter the gauges would die and then the truck would die. It slowly progressed to the point where it only runs for 45 seconds and there is no signs before hand. Does any of this happen to your vehicle? I have checked all of my cables and the main ground wires. Along with changing a few of the relays. Nothing has helped. My problem started with an electrical component heating up and quitting. Now it doesn't matter how hot it is in only runs for a couple seconds.
Jul 07, 2014 | 2003 GMC Yukon XL
Hitachi Chain Saw won't start hot
check for spark when it fails to start could be a bad coil
Aug 10, 2012 | Garden
My 435 Husqvarna chain saw runs great but on hot summer days when I turn it off and go to restart it 10 min later it will not start. had the same problem with it last summer and took it into the local...
The carburettor is getting too hot and fuel is being blocked from feeding into the engine. Make sure that the carburettor is clean and has adequate cooling while the engine is running. If you still have problems withs starting, blow the carburettor cool or use a damp cloth to cool it if starting is a problem.
Jul 13, 2011 | Husqvarna Chain Saw 20" Bar
I have a poulon p4018wm chain saw that runns but after it gets hot you have to wait for 30-45 minutes before you can start it again
if it gets too hot say from dull blade or not enough lube on chain it can cause gasoline to change to a gas
May 18, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Hot chain saw wont start
When it won't start, remove the spark plug, lay the base on engine metal with the wire on, and pull through. The spark should be blue and snappy. If nothing, try a fresh plug. If still nothing, the ignition module may be failing with heat. Try blowing out sawdust from the engine and case with compressed air to improve cooling. Does the engine 4-stroke when not cutting, but immediately 2-strokes when cutting? Check the air cleaner and muffler for plugging. Make sure the carburetor fasteners are tight. Hope some of this helps!
May 01, 2010 | Garden
Stihl saw 026 runs 5-10 min won't stay running and backfires
5 to 10 minutes is a long time and the 026 is a fairly old saw. If it is running 5 to 10 minutes and not 5 to 10 seconds, you probably just have a worn engine. Clean the saw inside very thououghlr and try Amoco white gas. You should be able to reduct the heating and get more run time. A carb rebuild might also help some but in hot weather it is not unusual for chain saws to vapor lock.
Sep 21, 2009 | Garden
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Stihl Chainsaw Air Filter Element 028 Chain Saw O28 Logo
282 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
