Question about Hatco Corporation Compact Electric Booster Water Heater - 18in W x 24in D x 12in H - 208V - 3
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
  • harveyj373 Sep 12, 2010
    I should have explained that it was a 3 phase heater, and I have 3 phase and the wire is there from the panel to the heater, I just want to know how the wires should be hooked to the terminals that are labled 1-2-3
    Sergeant:
    Novelist:
  • 193 Answers
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Posted on Sep 11, 2010
Tested Elec and have 240 at wall box but when hooked up (wired) unite does not come on.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
How did you test for 240?
How is the unit wired?
Which brand and type water heater do you have?
What product are you hooking up to 240V?
What does product label show?
Is this electric tank-type water heater, or electric tankless?
Is the water heater new? Or older heater?
Have you pressed in reset button on tank-type?
Add a comment for followup.
Gene
h
Sep 16, 2013 | Rheem Water Heaters
I have a Hatco c-6 and it is set up for 208 volts 3 phase hook up and the terminals are labled 1-2-3 in the heater.. I have 3 phase and the wires are from the 3 phase panel to the heater..the wires are...
Thanks for your reply. The order in which you connect the wires 1-2-3 does not matter, all three terminal block screws will accept any one of the hot wires from the breaker, one hot wire per each terminal screw.
Sep 12, 2010 | Hatco Corporation Compact Electric Booster...
I have a Hatco booster heater, and it is 3-phase, and the terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
I beleive that would be fine.the only reason phase would make a difference is if it had a motor in it.If you hook up a three phase mtr and it runs clockwise to make it run counterclockwise all you have to do is switch two of the three legs.If you hook it up 123 ,132,213 it will be fine. just make sure connections are tight and you have a ground.
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
Need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
New water no hot water
Hello, I just noticed this question, which provides more info than your other one did. I thought you had an existing (older) water heater and provided info for checking a potentially faulty, (failed) heating element.
After seeing and reading this question, it sounds as if you have a problem with the 220V-AC electric supply going to the water heater. I would start by checking the circuit breaker to verify that the breaker is operating properly, since it might be that you're only getting one side of the breaker to pass electricity to the water heater, meaning that the heater isn't going to be able to operate at 120 volts properly.
There could also be a bad connection at the water heater when it was installed, or a break in the wiring from the electric panel to the water heater. Check at the circuit breaker panel first, being careful to test the breaker with a multi-meter to verify that the breaker is passing the voltage from panel thru to the screws that the wiring is connected to.
You will need to follow the circuit from the panel all the way to the water heater, taking care to check any connection points, such as a possible junction box. However, the wiring from the panel to the water heater, should be one continuous run without any other junctions or splices, so if the wiring is faulty, you will need to replace the wiring to be in code compliance.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rinnai *85e remote hooked up no hot water and no reading on remot
did you turn the unit off before hooking it up ? Any function on a tankless rennai the pwer has to be turned off and the priority button has to be pushed in,, if you have the manuel it tells you haw to do this,,
Feb 24, 2009 | Rinnai Digital Remote Water Heater Control...
Hatco Corporation Compact Electric Booster Water Heater - 18in W x 24in D x 12in H - 208V - 3 Logo
253 people viewed this question
Top Hatco Corporation Water Heaters Experts
Donni Steen
Paul Carew
Are you a Hatco Corporation Water Heater Expert? Answer questions, earn points and help others
