Question about Maytag Dryers
It takes a long time for my dryer to dry - Maytag Dryers
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
It is taking far too long to dry, this has only recently started? what could be the problem?
Does it get hot? If it does, then the problem is reduced air flow, caused by a lint filter that hasn't been cleaned, masses of fluff in the exhaust pipe (usually on bends), or the external vent not opening properly. Birds can also nest in the vent pipe if the vent isn't protected or is broken.
If it doesn't get hot, you need a new element. Some dryers have two elements if the dryer has a high and low setting. just one element can fail.
Jan 20, 2016 | Zanussi TC7102W Electric Dryer
Dryer takes a long time to dry
If the dryer won't takes to long to dry, check the venting. A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time.
Nov 12, 2012 | Kenmore Elite HE4 Electric Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Dryer not drying clothes is taking two to three times to get dry
If your
Dryer Maintenance
heatman101
Feb 06, 2011 | Roper REX4634KQ Electric Dryer
It takes too long to dry the clothes, it is getting to where it takes twice as long as it used to. it does not matter whether I use the sense dry or time dry.
heatman101
Nov 21, 2010 | Whirlpool Dryers
Kenmore Elite Gas dryer Model 11077052600. Dryer takes a very long time to dry the clothes. A full load could take 3 hours to dry. Washing machine is spinning out the water properly. this seems like an...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 09, 2010 | Dryers
Dryer takes long time to dry clothes
Remove the rear connecting vent and try a load at 45 minutes time dry. If it dries correct the vent blockage problem.
If not, let me know for step 2.
May 23, 2009 | Kenmore Dryers
RE: Dryer takes more time to dry clothes
Hello mehta1007,
If your dryer is taking more time than normal, you may have one of a few problems with it.. The most obvious place to check is the exhaust duct system. Many times when the dryer is trying to move moist air out of the dryer and if the exhaust system is restricting air movement, the dry time will be extended. So that would be the first place I would look.. Check the exhaust end baffle too ( outside ).
Please let me know if that was your problem and other details if it was not..
Good Luck..
Regards,
Rick
Nov 23, 2008 | Kenmore 63942 Dryer
Dryer takes a long time to dry.
This sounds like the vent is plugged up. The dryer gets rid of moisture through the dryer vent and hose. When this gets plugged up it will take a long time to dry or the hi limit will shut it off. When the dryer vent or hose is partialy blocked it will take vary tong times to dry the clothes and will eventualy cause the dryer to stop drying all together.
Nov 14, 2008 | Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
41 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
