Question about Toshiba Televison & Video
Hi - have a 3 yr old Toshiba 42X3030DB and Freeview/Digital services have stopped working - have plugged in stand alone Freeview box which keeps freezing the picture. Is there a fix for the inbuilt Freeview please? Thanks in advance for any replies. Paul...
Highdefjeff
  • 124 Answers
SOURCE: Freeview wont work
Have you changed to "source" or "mode" or "input" to correspond to the different inputs?
Posted on Apr 08, 2008
  • 5 Answers
SOURCE: Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Posted on Aug 13, 2008
SOURCE: My Thompson Freeview box keeps stuttering/time lapse freezing.
Hi Ive just bought a thomson dtr box and the picture keeps freezing .new arial new cable etc.well ive just tried a £20 freeview box and its fine good clear picture and dosnt freeze.I had a good signal when using the thompson box and its the box load of rubbish taking it back to shop.
Posted on Sep 25, 2008
SOURCE: No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Posted on Jan 13, 2009
SOURCE: I Bought a Goodmans 250Gb Digital Freeview box in
As it's only May, I would take it straight back to the shop and demand a new one/alternative.
If it is bust, and it's in warranty, I certainly wouldn't try and fix it as you may invalidate the warranty by opening the case to check wires etc.
Posted on May 14, 2009
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
Cant get freeview
go to menu put it on dtv scan channels/if not its aerial
Apr 18, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
42"lcd samsung tv,one year old has stopped working on digital and analogue but can work with a sky box or freeview box,ie it will not work on its own,thanks 42" lcd samsung wont work without a sky or...
sounds like it needs a re set
you need to press the following: (do not hesitate between presses)
s/by
info
menu
mute
s/by
when the tv comes back on follow original installation set up
Sep 04, 2009 | Samsung PPM42S3 42 in. Plasma Television
Nov 24, 2008 | Televison & Video
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Do not understand how to set up my alba digi box to my television and recieve basic digital channels help!
Hi.
Ok
1) plug aerial in to the antena in sock on freeview box.
2) plug short aerial type lead in to rf out socket on freeview & antena in socket on TV.
3) plug A scart lead in to the socket marked TV on freeview box & the other end of scart in to one of the scart sockets on the TV.
If your TV has more than one socket plug it into the one marked AV1 or AV2.
4) plug in freeview to mains electricity & switch box on.
5) Turn TV on freeview should appear automatically if it doesnt look on your TV remote for A button marked AV or a button with either A circle or square with an arrow going through it you may need to press this several times until you see digi picture come up.
Thats basically it but do check that you dont need a new aerial etc to be able to get digi signal in your area.
http://dysonmanuals.llc.nu/
Jul 26, 2008 | Televison & Video
Hi, i have a problem with my toshiba regza, 32" about 18 months old, keeps changing screen width to 4:3 from widescreen on some of the music channels on sky! keep resetting it but still does it next...
Hi Debbie,
Check the picture format setting on your Sky box.
Press Services.
4 for set up.
1 for Picture.
Theres and option that says 16:9, 4:3 or 4:3LB, make sure its set to 16:9.
Then go to Save settings and press the Select button to save the setting.
Regards
Andy
Jun 26, 2008 | Toshiba Televison & Video
Hi I'm trying in install Freeview but it doesn';t work. Do I need to have the TV on AV?
Hi.
If your freeview box is not built in to to TV set & it is a seperate stand alone box it must be connected to the TV using scart lead.
Then press AV on tv remote if it doesnt automatically show on TV screen.
Chris.
Mar 07, 2008 | Televison & Video
Televison & Video Logo
171 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
