Question about Whirlpool LER4634J Electric Dryer
What guage wire is requiured for conecting the dryer to the pannel box?
  • Whirlpool Master
  • 43,501 Answers
The minimum gauge wire is #10/3 w/G...
heatman101
Posted on Sep 12, 2010
1997 force merc 50 hp fuel starvation when running at speed when running at 4000 rpm for 5-10 min. engine starts to act like its not getting fuel, carb rebuilt,fuel pump rebuilt,new hoses and filter
it indicates that the fuel tank is not venting properly
or that the hoses from the tank are getting a blockage or a rust blockage in the tank pick up line
AS you stat that it runs good at rpms lower that when it requires full fuel flow , I would be concentrating in the area of the tank , primer bulb and hoses
If you have made the mistake of using e fuel mix at any stage , the ethanol attracts water and promotes rust and rubber degradation as well as metal corrosion
the high fuel consumption indicates that it requires a tune up so because it is a unit that requires utmost safety , I suggest that you use an accredited service center for the job
Apr 16, 2017 | Boating
Electrical issue...220 dryer outlet problem
ok start at the pannel is there a double breaker there
usually a 30 amp two pole breaker this is how a pannel works first breaker pulls 120 off of one side of pannel second breaker pulls off 120 off the other side of pannel if you look the buss bars you will see that they interchange from one side of the pannel to the other so at the breaker you are checking make sure you have 120 v on output of one half of breaker and 120 on second half of breaker when you use a volt meter put one side to gng the other side to wire comming out of breaker you should have 120 on both sides if not you have a bad or tripped breaker
Apr 24, 2010 | Hammering
Dryer burns off wire at heating element-why?
Poor conection. A lose or poor fitting wire terminal will creat heat at the conection. Undersized wire will also make heat and burn wire.
Oct 31, 2009 | Amana DLE330RAW Electric Dryer
Sound
Try making sure all wires are of same lenght and guage as well as correctly conected.
Aug 20, 2009 | Car Audio & Video
Dryer electrical problem
try a continuity test on both wires when plugged out all the way to the relay board from the back panel to check for a wire break hope this helps
May 16, 2009 | Whirlpool GEW9250 Electric Dryer
94 ford probe,speedometor,oil gage,odometer not working
You need to pull the dash and check the guages look for any burning or melting. You may just need to replace the pannel in your dash, pretty easy work. If not start checking the wires and cables that come out of your faulty guages.
tepfy
Feb 22, 2009 | 1994 Ford Probe
Wiring Shortage
Check the fuse box for a loose fuse.it would be under acceseries.If thats not it you have a loose plug in on you'r dash.
Jan 10, 2009 | 2002 Dodge Ram Maxi
Wiring diagram?
They ain't power leads. They carry heat element current from the cent sw when the motor is running.
Jan 10, 2009 | Dryers
Kenmore ele dryer
Remove the ground strap from the middle terminal block in the dryer. Attach the white wire to this terminal. Take the green wire and attach it to the frame of the dryer. Attach the red wire to the right hand terminal, and the black wire to the left side terminal.
Jun 07, 2007 | Kenmore 62722 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
