Question about Black & Decker 12-Cup Programmable Coffeemaker
It is warming the pot but not perking. Why? - Black & Decker 12-Cup Programmable Coffeemaker
  • 17,129 Answers
The temperature is not good enough. have your set the program for the optimum required for steaming.
If not try again with another program with a longer time.-higher heat.
Posted on Sep 11, 2010
  • eyecam Dec 20, 2010
    usually on coffee machines have 1-2 thermal switches that turn off main thermal heating element of boiling temps shut off so the plastic housing does not melt , but , the heating on the hot plate ,element is on only when the the machine is on or set to brew. most machines have a thermal fuse 8-10 amps if blown no perking but may only have the hot plate on they can be bought at Radio Shack, since coffee Machine are mostly made in Chine so cheap just consider
    the time and cost before tearing into an electrical item >^.^<
3 Suggested Answers
  • 176 Answers
SOURCE: Doesn't perk long enough
Hi you have a pot made in China, 1 of 2 things are broken. 1 the thermostat, 2 the keepwarm element. 9 out of 10 times it is the thermo.You can not buy them in the USA. I have a auction on eBay and I cab make the parts out ob USA parts. Mt eBay name is ron622c, you can take a look. Go to Farberware coffee pot parts. Good luck. Ron
Posted on Jul 26, 2010
  • 176 Answers
SOURCE: Vintage Sunbeam C50 doesn't heat enough to perk.
Hi. If you have a light on your coffee pot the model # should 122. A 12 cup older pot. I can fix it for you but you should consider the cost. I only charge for thr parts you need. Shipping both ways is about 10.00 , Max on the repair will be 15.00. My email is callahanronals@att.net Good luck. Ron
How can I fix my 55 cup Farberware coffee urn FSU 255 model and it won't turn on. Any suggestions? It's always worked well before--this is a new issue.
If it will not perk or even get warm, the main heating element (usually in the middle of the pot) is probably bad. Get an ohm meter and read the resistance directly at the pot terminals (looking into the pot) (before taking the pot apart). If you get a infinite reading (or in the thousands of ohms), the perk heating element is probably bad. On my small pot, that element appears not to be replaceable...but pull the base off and see.
If you pull the base off, you will likely see three components; main perk heating element in the middle of the pot, "keep warm" element - may be covered in braid) skirting the edge of the pot, and finally the thermostat that allows the pot to perk for 7 minutes then opening up the circuit to allow current to both of those elements in series just to keep it warm.
Although I don't have a pot exactly like yours, in my smaller pot, the "keep warm" element (covered in braid) and the thermostat (little button pressed by a spring and screw against the bottom of the pot to sense temperature) can be replaced...go to Goodmans.net.
Jul 23, 2014 | Farberware Coffee Makers & Espresso...
Why doesn't percolator run long enough
The thermostat in the base of the pot needs replaced...it is the little round thing pressed against the base of the pot. (You can see it after removing the base of the pot.) Pull off the leads and remove the screw holding it in and get a new one at goodmans.net ($10 including shipping...I just got one from them.)
You should take a picture before removing anything to make sure that you get the leads connected up correctly.
You have a main perk element and a keep warm element in the base of the pot. Plus a thermostat pressed against the bottom to sense temperature. Upon plugging in a cold pot, the thermostat reads zero ohms and applies 120 volts all to the perk element. Then when the thermostat senses a high enough temp, it opens and 120 volts is still applied to the perk heating element, but this time through the keep warm element (about 200 ohms or so). So now the perk element although hot is not hot enough to continue perking, just keeps your already perked coffee warm.
On a cold pot, you should read about 17 ohms looking into the pot...on a warm pot (with the thermostat opened up) you will read in the hundreds of ohms.
May 11, 2014 | Farberware FCP280 Stainless Steel...
Perks ok coffee lukewarm
After perking the coffee the pot is to switch to a thermostat to keep the coffee warm...that thermostat is probably bad...
Not sure if it is replaceable on those pots...
Would call the Customer service number for the Regalware...
http://www.regalware.com/customer-service/contact-us
heatman101
* Contact
262-626-2121
1675 Reigle Drive
Kewaskum, WI 53040
(google map)
Dec 08, 2010 | Regal Ware K1301 Coffee Maker
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
Why does my FCP412 farberware coffeepot not keep the coffee hot?
<br /> KEEP WARM ELEMENT<br /> <br /> <font size="3"><font face="Times New Roman"><span style="mso-spacerun: yes"> </span>The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. The KW element is $8.00 and $2.00 S/H. <a href="mailto:callahanronald@att.net">callahanronald@att.net</a></font></font><br /> Ron<br />
Aug 23, 2010 | Faberware FCP412 Coffee Maker
The first problem we noticed is the coffee is not as hot as it used to be, but it was still strong enough. Now the unit perks for about 10 min for a full pot, the light comes on....but the coffe is weak...
Hi, The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix. Thanks and please ask if you need more help. Ron For the part go to repairshack.com
Aug 17, 2010 | Faberware 10-22 Cup Coffee Urn
Hi. Sorry to say your problem is one of two items, the keep warm element. KEEP WARM ELEMENT
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K W element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K W element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. You will know the KW is working,if left alone and pluged in the water gets hot and hotter
I sell all the pot on eBay under ron622c From the model # you have a China pot. Good luck. Ron
Jul 23, 2010 | Faberware FCP412 Coffee Maker
May 28, 2010 | Faberware FCP280 Coffee Maker
Faberware FSU-122 coffee maker does not perk
Oct 16, 2009 | Faberware FSU122 Coffee Maker
Black & Decker 12-Cup Programmable Coffeemaker Logo
176 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
iandunn_tms
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
