Question about Bosch Freezers
I have a freezer that does not keep tempreture. When I set it to -18 it will not get any warmer than -13 and if I try a super freeze it will take it the best part of all day to get to -18 and then it falls to -13 within 2-3 hours. I am worried that if I do not keep super freezing then it will get warmer and all the food in the fridge will defrost and I will lose it all.
    Problem Solver:
  • 10 Answers
That you can get down to -18 suggests the compressor works and there is enough gas to get on with. Check the seals of the freezer for a heat leak- it should be able to grip a piece of paper in the door when it's shut. If the seal is bad then the paper will fall out or come with a gentle pull - order and replace the seal.
Posted on Sep 11, 2010
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
I just bought a used (but never installed) wf 1061 (freezer with a wine fridge). the unit and dsidplay lights up as normal...but i don't hear the compressor starting...can it be in demo mode?...
Try this also:
Super freeze 5 seconds set desired temp press super frees briefly again then adjust the wine cooler temp press super freeze again briefly, Next press menu and select normal. Then press menu again. To exit press super freeze again until it no longer blinks.
Kelly
Aug 28, 2011 | Freezers
It is not wanting to freeze. but it does keep things frozen. and some times water does come out at the botton
Hello
Check that it set cold because its not below -2 or -5 thats why dose not freeze anything it needs to be at least by -10 to -18
Jun 04, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
My holiday freezer keeps freezing up
most refrigirators have an adjustment knob, set your desired tempreture and allow 24 hours for adjustments
Mar 02, 2011 | GE FUF17SVRWW Upright Freezer
Prestige fridge-freezer has stopped freezing to the point where the freezer is now warmer than the fridge, pressing super-freeze doesnt work
only cause i can think of is the thermostat ,try a new one and see what happens ,sorry for not having a quick fixya
Jan 08, 2010 | Jenn-Air Freezers
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Freezers Logo
349 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
